SOURCE: how can I unlock my sony bravia remote
Your Sony set is not locked. It has some other fault. If the standbylight blinks, cound the number of blinks at one time. It is fault indications. For more details, type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments. Pull up older posts. You can get all details. You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
SOURCE: My innovage jumbo remote does not work with my hd
Your issue is very common. Unfortunately these two items are not compatable. You will have to use the two remotes as many, many folks do.
SOURCE: Replacement Sony RM ED009 remote not working
Remote sensor on the tv may not be working. Try using a camera by aiming the remote IR sensor of the remote control at the camera lens then press and hole any button and check if you see a flicker of light. If you do, the remote control is transmitting, if not, the remote control is not working. This will tell you if the remote sensor on the tv is not getting the signal from the remote control
