Mindscape PrintMaster Premier 7.0 Logo
michelle Posted on Nov 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't this install on my laptop?
I put install disc in & nothing happens
vtec
Level 3:
Master:
  • Master 371 Answers
  • Posted on Nov 10, 2012
vtec
Master
Level 3:
Master:
Answers
371
Questions
Helped
85179
Points
1111
If you are using windows, go into "My Computer" and look for your cd/dvd drive . Right click , choose explore and double click on any file that looks like "install" or "setup"
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
1helpful
My Medion laptop won't boot windows; black screen
Unplug, remove battery, Remove and reseat Memory Mods, try to reboot. If no, Remove HDD and test, replace if necessary. Has their been any damage? Dropped?
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Screen on presario 2500 is black blank and won't change
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
1helpful
My HP pavilion won't boot. I turn on my laptop and all it does is sit on the hp start up logo i press the function keys but all it does is reject it. This happened after installing windows 7 and the...
It seems there is no booting as the memory is not responding or the hard disc is not booting up. Please check on the back up CMOS button cell battery on the back side of the laptop. replace if the voltage is low.
Also remove and reset the memory, if not you need to take consensus to know if this can be the hard disc, memory or the motherboard.
I put the disc in. click install on the autoplay. and then nothing happens at all!! why won't the setup show up so i can install the game?
Hi anderswang92
It depends on your OS'es version . The fdriver doesn't run anymore under the most recent Mac and Windows versions .
Best regards ,
fanaudi .
Hii..I Am Having An Acer Aspire 5050...Well I Installed Windows Vista Ultimate On It But Originally It Was Windows Visa,Therefore,After Installing Windows Vista Ultimate I Tried To Upgrade The...
A solution to that is to install Windows Vista Ultimate on top of your old vista installation. Just insert your Vista DVD and restart your computer. And simply follow the instructions for the installation.
If you place your Win7 disk in the DVD drive boot the laptop from the disk and choose to install a new system.
Follow the menu and prompts.
When it has installed download the drivers from Acer.com otherwise you will get problems.
Hope that helps.
Installation disc will not work
You don't need the Olympus software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Top Mindscape Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mindscape Computer and Internet Expert? Answer questions, earn points and help others
