Question about Radio Communications
The scala rider Q G A won't pair with my I Phone it keeps saying swich your scala on
The name scala comes up on the I Pone but it will not pair my old Ncom BT" had no probles pairing help
    New Friend:
The scala rider Q G A won't pair with my I Phone 4S it keeps saying nothing
Posted on Dec 01, 2012
SOURCE:
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Posted on Jul 13, 2008
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Posted on Feb 09, 2008
SOURCE: bluetooth to mobile pairing
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
kozachek
  • 122 Answers
SOURCE: the headset was paired with old phone, but will
Have you tried putting the phone back in to pairing mode? To do this press and hold the call control button while the power to the headset is off. Then search for the headset with the new phone. When the phone prompts you for the passkey, enter 0000
Posted on Mar 16, 2010
Testimonial: "Thank you this worked out great. Just continue to hole the call button down until it flashes red and blue. Then it will pair with the new phone or device"
My scala rider g4 detects iphone but does not pair
All I did was clear it from the phone and made sure I had a full charge on my scala. Then I just reconnected it. That was it. Once I had made sure I had the full charge that was it.. Done. Hope this helped. Regards, Denise
Jun 09, 2014 | Cardo scala 700LX Bluetooth Headset
Not pairing with other devices
Have you turned blue tooth settings on your phone? Also you can pair your phone if the Bluetooth is working. Otherwuse you may be out of range. If that does not work have someone else try the bluetooth to eliminate the problem is with your phone.
Nov 15, 2013 | Cardo Scala Rider Teamset Pro
Scala rider connects to phone 1 and phone 2 and after 10-15 seconds it shut down
give it back. I also have problems with my Scala rider Q1 system. I would not pay R 200 FOR THIS TYPE OF RECEPTION and i have payed R3000. Bad deal.
Oct 29, 2013 | Scala-Rider Cardo Scala Rider Q1 TeamSet...
I HAVE LOST THE INSTRUCTION MANUAL & WANT TO USE THE SCALA RIDER WITH MY garmin nuvi sat nav
Please find here a link to google search where the first 2 results are for the scala rider headset
http://www.google.com/search?q=scala rider user manual
Jun 20, 2011 | GPS
Headsets won`t pair.
I am having the same problem. Did you ever find the solution?
Jun 02, 2010 | Rider Cardo Scala Q2 Multiset Headset...
Volume
I had a similar problem when I first connected my Cardo Scala Rider set to the helmet. First off, make sure that the volume on the Zumo is set to 100% for BOTH guidance and mp3 functions. Then click the upper control on the Cado Scala to maximize the volume of the headset. When you've accomplished those two electronic hurdles, adjust the location of the speakers in the helmet - if location of the speakers is not optimized nothing you do with the electronics will have much effect. I typically run the mp3 volume at 20% and the GPS at 50% with the headset volume at halfway. My Cardo Scala unit is a Teamset and I sometimes have problems hearing my rider scream that I'm going too fast. I haven't bothered yet to tell her to keep the microphone closer to her lips.
Aug 07, 2008 | Garmin zumo 550 GPS Receiver
Cardo scala rider operators manual
the ususal way to turn on a scala rider headset is to hold the symbol fo rabout 5 seconds then hold just behind the symbol for another 5 sec's untill the light blinks red and blue then it will be able to link to your phone for the first time. if it links automatically or you have already linked it then just let it do its thing near the back you will find a sectioned off aread and in the center it will have a raised button that is the talk / answer / redial button just forward of that there is a button (the one that you held to make it blink red and blue) that is the voice dial button the icon itself is just for on/off the two raised areas on the back next to the charge port are the volume buttons up/down respectively
Oct 04, 2007 | Lands Phones
Radio Communications Logo
994 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
