SOURCE: Whirlpool quiet partnerII dishwasher
Peace Friend,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
That unit has a stainless steel soft food disposer built in to it!
That should not be the problem!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
SOURCE: Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
SOURCE: whirlpool DU943 leaks heavily when filling from
I doubt the H2O tank temp would have any affect... to fix the problem you will need to pull the unit out and replace the supply line from the valve to the elbow... I would recommend braided line.
If your talking about the fill tube that loops up the side of the unit it usually is just seperated at one of the fittings and can be pushed back intp lace or recalmped... otherwise you will have to purchase a new oem tube.
SOURCE: Whirlpool dishwasher doesn't clean very well
Hi
Thanks for using FixYa. First of all please check the Water
temperature by using a thermometer inside the dishwasher to measure the water
temp. It should be as close to 125 degree F to 140 degree F as possible. Now
try using the temperature boost feature if your dishwasher is equipped with
this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store
your soap in a dry environment and it is not stale and clumping together.
Possibly try a different detergent like a liquid or gel. Also, make sure the
dishes are loaded properly, or dishwasher is not overloaded.
To check
the proper filling dishwasher will fill with water up to and around the heating
element. If water is more below the heating element, you may have low water
pressure or a problem with the fill valve. Try & listen if it sounds like
it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the
entrance of the fill valve, sometimes the fill valve can fail and not allow the
proper water into the dishwasher and may need to be replaced. And, check
the spray arm and pump cover for splits or leaks. Also make sure that the water
is draining and is not accumulated in the dishwasher, if it is in
dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with
today's dishwasher.
Please do
rate this solution and revert for further assistance.
Thanks
Rylee
SOURCE: I have a Whirlpool dishwasher, model DU943 that's
Hello- This unit has a thermal fuse inside the door panel on the control. This part is replaceable. If it is bad, replace.- and would suggest not using heated dry as this is most common cause of fuse failure. Let me know if this info helps- have more if needed.- Thanks- ED
