Warning light for engine showing up on dash board
SOURCE: electrical fault on peugeot 406 hdi
lift the carpet at o/s/f {drivers front footwell} there is two multiblock connecters guarenteed tobe sodden with water disconnect connectors& dry with a hair dryer on low setting hopefully the pins are not corroded reconnect connectors this is aknown fault i have worked with peugeot&citroen for 24 years kind regards alastair
SOURCE: engine oil light is showing on the dash board after switching on
Most important thing you need to do is to establish the actual oil pressure. put a mechanical gauge on the engine and read real oil pressure. If pressure is low (min is 15psi, I prefer to see at least 20 at idle) there is an internal problem...bearings etc. If pressure is good, sending unit has failed...replace it. I would not drive it 'till the oil pressure is verified as being safe. You might get lucky and someone just forgot to plug in the sending unit, but it must be checked!!!
good luck
SOURCE: Yellow dashboard light on in shape of an engine
It is the check engine light, the computer has detected a fault, and has stored it in memory.
The vehicle needs to be connected to an OBDII handset to read the codes. If you live in the US, take it to any Auto Zone store and they will read off the codes for you, once you have the codes, you are on your way to finding the problem. This may be possible at other major auto parts stores but you will have to call your local store to confirm.
Hope this is of some help.
Ed
SOURCE: engine light on . fault code p0411. air solenoid stuck shut. show
P0411 Secondary Air Injection System Incorrect Flow Detected
p0411 is a generic code, probably a vacume leak,vacume hose broken check this first, check the air pump turn on the car but it needs to be cold, you should hear a high pitched whine, this is the air pump running,there are 2 hoses one suction one blowing thishose should be going from the air pump to the air cleaner disconnect that and see what the volume is should be pretty strong.
But mostly you probably have a broken vacume line somewhere
SOURCE: Scania 114G 340 is not running after EDC warnings,
the fault codes 53-54 is problem in cylender 3and4 unit injectores but that is not the main cause to make the engine is not starting check the overflow valve and the fuel pump or another fault code in the control unit
