Question about Emerson MW8168B Microwave Oven
Keypad Problem? Upon plugging in the microwave, you get flashing zeros on the clock/timer display. You can initially input an amount of time after pressing the cook button. Upon pressing the start button you get no light, no microwave sound, and no timer countdown. If you decide to set the clock after plugging in the microwave, you will get 'Err' displayed on the clock/timer. I thank you in advance for your attention in this matter.
  • 883 Answers
Look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
Posted on May 25, 2007
SOURCE:
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
    According to the manual this is how to set clock.
    To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
    Enter time of day. The time appears in the window; the colon continues to flash.
    Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
    If you need the manual it is on link below.
    http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
    Good Luck
    Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
    Round soft key OXO Timer I need to change the clock time their model # is 1061978
    Operating functions:
    To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
    To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
    When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
    This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
    Sep 18, 2010 | Microwave Ovens
    How to set clock on sharp microwave
    normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
    Sep 21, 2009 | Sharp R-1480 Microwave Oven
    Operating Instructions Mistral MMW17SS
    Hi Bryan... I had the same problem as you in trying to work out this blasted clock!!! - by fluke I worked it out!!
    Here are the steps:
    1 - press the 'clock' button (to ensure the clock is displayed) 2 - press the 'cancel' button (the display will go to zero '0' 3 - use the keypad to enter the time (at this stage the colen between the hour and minute numbers will not be flashing. 4 - press the 'clock' button again (the colon will start flashing and the time will be set.
    your frustrations are over my friend!
    May 07, 2009 | Microwave Ovens
    Sanyo microwave clock reset
    This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
    1. Unplug the unit for a minute then plug unit in.
    2. Press the clock (clock/timer) button once.
    3. Using the keypad, input the time you wish to set.
    4. Press the clock (clock/timer) button once.
    5. Press the stop/clear button, Time should remain.
    Hope this works, if not, let me know.
    Please take the time to give this solution a fix ya rating.
    clarkco
    Apr 12, 2009 | Sanyo Microwave Ovens
    Microwave oven (nn-sd997s) stuck in DEMO mode
    Pressing "timer/clock" button 4 times turns on and off demo mode.
    Apr 26, 2008 | Microwave Ovens
    GE EMO3000 Over the oven Microwave
    Do you know if the fuse blew again? You may have a problem with the powers supply section that powers the main board. The main board controls the display and receives input commands from the keypad.
    Please let me know if I can be of further assistance to you.
    - Jim
    Feb 24, 2008 | GE EMO3000 Microwave Oven
    Emerson MW8168B Microwave Oven Logo
    358 people viewed this question
    Top Emerson Microwave Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Jerry Greenberg
    Jerry Greenberg
    Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
