Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
Anonymous Posted on Nov 10, 2012
Flashing PF 32 error code
This is a double wall oven. Both ovens are flashing a PF32 code and the oven will not turn on. I removed power for 10 minutes and then turned back on. After about 30 seconds the oven started beeping and flashing the PF32 code. I cleared it. Was able to program bake at 350F. The relays cycled, but then the oven started beeping and flashing that code. It does the same thing for both ovens. I can't find the PF32 in any documentation. Any ideas?
  • Anonymous Nov 10, 2012
    I tested the temperature probes today (upper and lower) and they both look good. I also check the resistance at the relay board and the resistance is the same, so the wiring looks good too. I guess this must mean there is a problem with one of the boards. Since I hear the relays working, I'm going to guess it must be the ECO. I wish it wasn't such an expensive guess. Let me know if you have a better idea.
  • Anonymous Nov 17, 2012
    I popped in the new EOC today and we're back in business!
  • Official Brand Answer 4,342 Answers
  • Posted on Nov 13, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467812
Points
5907
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
  • Anonymous Nov 15, 2012
    Thanks for the input, Mr. Polk. I was thinking the same thing, which is why I tested the probes. The resistance is as expected at room temperature all the way back to the board. This is what now leads me to think there is a problem with the electronics. Is there another sensor that could be the problem?
5 Related Answers
Anonymous
  • 6784 Answers
  • Posted on Jun 01, 2009
SOURCE: Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Anonymous
  • 6784 Answers
  • Posted on Apr 02, 2009
SOURCE: F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Anonymous
  • 3361 Answers
  • Posted on Apr 11, 2009
SOURCE: F1 error code plus constantly beeps and Oven won't shut off
ERC is bad and must be replaced.
(The Clock).
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Dec 31, 2009
SOURCE: Frigidaire double oven beeping and showing f8 code
Hello there
First i would unplug it for 1 hr to allow the oven internal reset to reset it'self than plug it back in and see what happens but if this doesent help than here is a listing of the code and what it means
F8 Lock motor relay watchdog is ative when it should be off Microprocessor checking the operation of the EDC lock relay after self clean is selected, relay failed. Replace EDC.
Lock switches Check or Replace component
Anonymous
  • 43501 Answers
  • Posted on Jul 30, 2010
SOURCE: F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
http://www.appliancepartspros.com/whirlpool-blower-w10176670-ap4369539.html
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Flashing
switch off the oven..remove the power cord from mains..keep power button pressed for approx 15 seconds and then plug in the power cord and try using
My oven is always flashing PF what does that mean
"PF" stands for Power Failure. There should be a reset procedure in your user's manual. I cannot specify this since you don't give the manufacturer or model number of your oven.
Jun 24, 2015 • Ovens
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
2helpful
Frigidaire Gallery Series Electric Oven has stopped working. I was trying to preheat the oven and after a few minutes heard a very loud pop/bang. The oven had the PF (power failure) symbol flashing and my...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
2helpful
Exactly the same problem. My oven is 11 yrs old instead of 10
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Kenmore double oven flashing "door locked"
4helpful
2answers
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
