SOURCE: Code to configure the Universal Remote for my Jwin DVD player (VD141)
jWIN products do not have a series of uniformed universal remote codes, therefore, they can not be provided at this time.
SOURCE: Need a new ac adapter for a DVP615 portable dvd/cd player (Zenith
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger cord ZENITH DVP615
SOURCE: Code to program my RCA Universal Remote to work my Jwin DVD Player
i need the remote code for a JD-VD5503
SOURCE: what adapter can we buy to plug the venturer
What I did with mine is check eBay for a 12 volt, DC LCD monitor adapter. These normally have sufficient amperage to handle these players.
I did a search on eBay today using search phrase:
"new power supply ac adapter for LCD monitor 12v 5a"
and came up with one for about $14.00 with shipping. You will need to check the plug when you get it and, if it does not fit, get one from Radio shack or, as I did, cut one from an old adapter I had laying around.
Most of these units require that the positive side goes to the center conductor of the plug (check the diagram on the player case over the plug to be sure) so make sure you set it up the way the diagram shows or very bad things will happen to your player.
You may be able to find a 12 volt adapter at Radio shack or somewhere else but these units need (according to the specs) about 1 amp from the supply to work and charge correctly. You "may" be able to get by with an 800 milliamp supply but I have not tested this.
Good luck
