Check engine temperature, fan operation and thermostat. Also check inside blower operation. If intermittent, then check and/or change the blower motor.
Try installing a jumper across the N/O terminal at the relay socket. Temp sensor in the radiator or in the thermostat housing supplies the signal for the relay the other relay signal is supplied by A/C in on position. both fans will run continuous with A/C on. One fan runs intermittent relative to water temp. Be careful not to blow a head gasket. If you leave the jumpers in place, the fans will stop when the ignition is turned off, save the engine until you isolate the relay signal problem. then simply remove jumpers and reinstall the relays
The power connection to the fan motor on these is known to overheat and cause a bad connection.The fan motor is above the passengers feet.Next time the fan motor will not come on, switch the selector to high and wack the bottom of the dash above the passengers feet.If the motor does come on at that time,you may need a replacement fan motor and connector.REPLACE the fan speed resistor board when replacing the fan motor,which is right behind the fan motor.
