My dishwasher is 5 years old and suddenly started making a grinding noise while washing. It makes this noise even when running empty (so there is nothing hitting the arms) I think this model has a garbage grinding disposal. Could something be caught in there? How does one take it apart to ck? Is there any site with diagrams and instructions? thanks
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
SOURCE: dishwasher does not drain
If you cannot get the diswasher to drain there is some obstruction in the drain line going to the disposal. First turn the power off to the diswasher at the breaker panel then open doors under sink and follow drain line to the disposal there you will find a hose clamp(silver) that you must loosten with a flat blade screw driver ( get a bucket under the disposal) pull the drain line loose and dump out excess water and debris inspect area going into the disosal to make shure it is not clogged up
reverse your proceedure and reconnect the drain
Before trying the dishwasher take some ice cubes and run thewater then put in disposal and turn on that should clean the disposal
try your dishwasher I forgot to mention that theri is a strainer at the bottom of you dishwasher that you can remove to be sure it is not clogged up I assume that you have aready checked that
good luck
SOURCE: loud noise maytag dishwasher quiet series 100
Hi All,
I have had a Maytag Quite
Series 300 for some years now and have done basttle with it on may
occasions. I now consider myself somewhat of a veteran, although by
no means a repair expert!
Grinding Noise:
From either a clogged/blocked impeller or not enough water getting to
the impeller.
For a clogged impeller, it
is fairly easy to disassemble the washer to get at the impeller to
remove any debris or blockages.
For not enough water it
can be a number of things. First of all, you will notice that the
noise lessens if you add a jug or two of extra water. This is because
if the water level is too low, the pump impeller will get some air
mixed with the water & this is LOUD! Now for the causes:
Float – If the float
gets stuck in the wrong position (debris or water deposits), it will
not fill enough.
Float Set Wrong – Seems
thats some of these dishwashers have the float set a little too low
to let the dishwasher perform without grinding. A few pennies
attached to the float with a rubber band seems to help here. Don't go
too far or you'll flood your kitchen!
Timer – Some folks have
mentioned that dishwashers that fill on a timer will not fill enough
in the allotted time, if the water pressure is low. While this is
true, I have looked over the electrical & parts diagrams for the
QS300 and I do not see a timer listed anywhere. Also, the wiring
diagram appears to show that this dishwasher only uses the float to
achieve the correct water volume. I could be mistaken here.
Note that in VERY hard
water areas (like mine – TDS of 850 hardness or 49 Grains), the
plastic fins on the cover of the impeller get very choked up with
water salts and this can impede flow, leading to a low-water symptom,
when in fact, there is plenty of water.
Dishes Not Cleaning:
Poor
Water Flow – See above, all the above items will negatively impact
dish cleaning.
Poor
Q uality Detergent – After trying them all – Yes, all – Do not
use cheap detergent. Buy the brand names: Cascade or Electrasol work
well. I have found that by far, the little packs work the best. We
found that the liquid works second best and the dry stuff really
isn't up to the task at all, no matter which brand.
Spray
Wands Catching – We found that our lower spray wand was catching on
the bottom of lower dish tray, so I very slightly bent down the legs
that the wheels mount to in order to lift the dish tray/basket a
little and give the wand a little more room. This worked well.
Spray
Wand Nut Too Tight – The factory seems to send the dishwasher out
with the nut on the bottom spray wand tightened a little too far.
Loosening this a little bit
lets the bottom wand rotate much more easily.
Top
Spray Wand Not Meeting Receptacle – The top spray wand is attached
to a pipe that mates with a port (well, one of two ports, depending
on if you have the top rack in the “Upper or “Lower” position).
The pipe seems to have a tendency of missing the port. A well placed
elastic band will help here. Note that on our dishwasher, by the time
the first elastic band wore out, the pipe had been permanently moved
to the correct position by the gentle pressure.
Tines/Dish
Holders On Top Rack Falling Over – The tines (metal spikes) that
hold dishes on the top rack fold down by design. Issue here is that
they do it sometimes during the wash, causing the dishes to fall over
and block the spray. A few well placed rubber bands help here as
well.
Water
Salt Buildup – If you live in a very hard water area, you can still
get clean dishes from yor dishwasher. We do and we have VERY hard
water. Buy a gallon of vinegar once a month. Pour this into a clean
dishwasher. Turn it on so that it runs for 2 minutes to circulate the
vinegar. Open the door & let stand over night. Close door &
finish cycle. This will cut down significantly on the hard water salt
buildup in the washer.
It's
A Maytag – Sorry folks, it's true. I have learned (after purchasing
the dishwasher) that Maytag has run into financial difficulty in
recent years and has reduced build quality to save money. If you got
suckered into buying one of these, you will very likely never buy one
again. My opinion is “Do not by Maytag.”
Hope
this helps someone!
SOURCE: very noisy wash cycle
most times i have found a foriegn object in the pump. sometimes the machine will clear it itself but other times you have to take the pump apart. it is not too difficult but you will need a size T15 and T20 Torx aka (star) bit to get it apart. Just keep taking out screws until the filter flowplate lifts off.
SOURCE: Dishwasher is not draining correctly in the air
Hi and welcome to Fixya, I'd suggest you start by checking the drain spout of the disposer where they ( the installer ) connected the drain hose from the dishwasher and make sure they've knocked out the plug in the spout. **Turn off the power or unplug the disposer/garberator before performing any service** If the plug is not punched out, with the aid of a long screw driver and a hammer, or a firm smack with the palm of your hand you should be able to knock out the plug. Then reach in the disposer and remove the plug you`ve just knocked out, reconnect the drain hose for your dishwasher and you should be good to go. Thank you for visiting "fixya". Please take a moment to rate the solution provided here for you. Hope that help`s. Good luck. macmarkus :)
