You just need to import your songs into iTunes library, then make a playlist with the songs, connect your iPod to computer, iTunes will detect the iPod automatically, then click iTunes menu "File -> Sync iPod", the songs will be transferred from iTunes to iPod.
If iTunes not works for you, You may try this ipod transfer, it's a nice iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc. It's much easier to use than iTunes.
for syncing of songs in apple ipod u need to have itunes downloaded from google. then u import those songs into itunes and then syn it in ipod with previous songs removed
You need to drag the downloaded files INTO iTunes to get iTunes to catalog the files. Once they are in iTunes you can sync to your iPod.
-=/ Daft Tech /=-
I'm not sure about error -48, but most often an error like this is caused by a corrupt music file not being able to be copied and stopping the sync. First, see if you can sync another playlist that doesn't contain any of the same songs. If it works, then it's just a matter of figuring out which song is corrupt. If you watch what song the sync is hanging on, sometimes you can pick it up quickly. ...good luck.
Hi there, When you go into the ipod section on iTunes, click the music tab, make sure 'sync music' is checked and 'selected playlists:' is also, then check the playlist you want to use. Click 'sync' button
If that don't work go back to the summary tab and hit 'restore' and follow the instructions to reset the ipod, resync and all should be fine.
make sure on itunes it says sync all selected songs(make sure all songs you want to download are selected)then try to sync it again if thats not your problem it could be a bad i pod
If you are asking how to add songs to you iPod (assuming you want to use iTunes)
Sync your iPod with iTunes
Connect your iPod to your computer.
When the iPod icon appears in the iTunes window (below Devices), select it.
If the Summary pane isn't showing, click the Summary tab.
To automatically sync your iPod:
Make sure that "Manually manage music" is not selected.
Click the Music tab and do one of the following:
To
automatically update your iPod with all the songs and playlists in your
library, select "Sync music" and then select "All songs and playlists."
iTunes loads the songs and playlists in your iTunes library onto your
iPod, and deletes songs from your iPod that aren't in your library.
To
automatically update your iPod with only certain playlists, select
"Sync music" and "Selected playlists," and then select the playlists
you want synchronized.
To manually sync your iPod:
Make sure that "Manually manage music" is selected.
Click Music (below Library, on the left side of the iTunes window) and then drag songs and playlists to your iPod.
ditto! HELP!
