Maytag HAV3460AWW Top Load Washer Logo
Posted on Jan 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag floods when it drains
I have a maytag model # MAV408DAWN. Water spills out from the pipe in the wall when the water drains from the machine into the pipe in the wall. I have had several plumbers and the maytag repair people out, but have not found a solution. The plumbers say the pipe is the right size (2 inches in diameter) and there is no blockage, and that the problem lies with the machine -- the machine empties too quickly and overwhelms the pipe. Of course, the maytag people say it is not the machine, but that it is the plumbing. This has been going on for two years and is driving me CRAZY, not to mention ruiuning our wall and floor in the laundry room. Please help!
Thanks!
Ginko
Level 3:
  • Maytag Master 19,396 Answers
  • Posted on Jan 05, 2009
Ginko
Maytag Master
Level 3:
Answers
19396
Questions
25
Helped
8077366
Points
55462
If the flooding is from hose and joint in the drain system, or from the drain pump, then it is the machine.
If instead, as it looks, it is a return from the drain pipes on the wall, then the problem concerns your house drain line, in that case it is a plumber job.
Ensure that the leak is not from inside the machine, if it is not anything from the machine, then call the plumber.
3answers
The pipes froze and busted in my garage which cause water to burst in my Maytag Neptune front loader washer Now the water won't drain Please help
That machine has an electric water pump, The first thing I must ask is has it completely thawed out? There is a rubber hose that goes from the tub to the pump, if the water in the hose is still frozen in the hose or in the drain hose, it will not empty itself.Also the water water level switch is in the top of that hose. Another possibility, is the pump or the water level switch could be damaged. You can access the pump by taking the front panel off. That is not hard to do, requires removal of the door and a couple of other screws.
Maytag Atlantis washer drain hose is over flowing during rinse cycle
It probably has some coins stuck in the pump or a kink in the hose. If the washing machine won't drain, remove the access panel, and follow drain hose into machine and to the pump.You will need something to catch the water. Take pliers and sqeeze clamp and slide away from pump. Pull hose off and drain water. Remove coins from pump inlet and reassemble. If it is overflowing where it drains into the wall, you will need a pipe snake or a plummer.
My maytag model MAV3905AWW when it fills the water goes out the drain. the drain pipe is 34" off the floor
lift the house higher as gravity is all that stops the water from comming out unless the maytag has a shut valve try this and get back to me
3helpful
My maytag washer is not holding the water and it drains it before it washes. I tried it at different water levels and it kept on draining the water every time I start it.
Check and make sure your drain from the washer is not pushed to far down in to the WALL DRAIN PIPE Because if it is the water will SIPHON out faster than you can fill.. Pipe should only be down about 6 inches in to drain and secured... Hope this Helps
2helpful
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Waste drain does not take in water, spills out.
Replace the clogged drain pipe. You need a plumber. Washer is ok.
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
