Question about Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009
FF 6 code - Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number?This error code FF indicates a problem with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. Sometimes this procedure corrects the problem and sometimes it does, for only a short period of time. Usually in this case, the main board will need to be replaced.
Posted on Nov 10, 2012
SOURCE:
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What can I do? Freezer is not cooling, inside light is on. control panel is off, Temp shows blinking OF and FF
Might need a freon top up. If the compressor is functioning there may be in sufficient freon . This can be topped up. A repairman/technician can diagnose this fairly quickly
Jun 05, 2015 | Frigidaire Freezers
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Freezers
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
Wgat does ff mean on Frigidaire Freezers
Unit specific manuals need to be ordered from customer support at the manufacturer. Tell the support people you need the failure codes when ordering to be sure of getting the right manual.
Nov 24, 2013 | Frigidaire Freezers
Temp display flashing FF, OF, and O.
What brand , is this on the freezer door ? Possible error code or reset function. More info please.
Nov 17, 2013 | Freezers
The freezer says FF after it kept beeping. I unplugged it and plugged it back in and it hasn't helped. What else can I do? The temp was 25 degrees
Google your problem with the mfr. and the code ff and it will give you solutions. Do this if you don't have a manual or call dealer.
Feb 09, 2013 | Freezers
Error code FF on LFUH2157lm2
Follow through with google punch in code and model.
Feb 09, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sears brand CHEST freezer had beeping noise. I changed the 9volt battery. It still beeps every 10sec. and flashes the number 6 and FF
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009 Logo
153 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Jay Finke
Jay Finke
geapptech
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
