I recently changed my hard disk, but was able to reinstall and do a test print on my inkjet printer. However, now my bluetooth doesn't even detect my printer. I've tried the troubleshooting steps on the manual however nothing has come out of it. My bluetooth detects my other devices except for the printer. I am able to print though if I connect the printer via USB.
SOURCE: HP PSC 1610 All-in-one Inkjet Printer
Assuming this is windows XP, the first thing you need to do is use the install disc that came with your printer. During the install, the program will tell you when to plug in your printer then it will automatically find it.
SOURCE: HP LaserJet 1320 will not print
may be its problem *********** board. install another computer if you saw detect a new hardware so your printer is OK or no detect hardware devise then fault your printer mother board,replace it and buy a new mother board.
Best luck
xptareq2000
other help
[email protected].
SOURCE: HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
SOURCE: I've had my printer for
Welcome to Fixya
Try to reinstall the driver/software of the printer. If possible, please provide me the error message that you are getting on your computer. Try to install the printer with other computer as part of the test. Let us if you can print using other computer.
Please let me know the result of the test.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: my HP deskjet F4180 printer does not get detected
thats a cable usb problem ,, try to change it
