My copier gestener afficio 3222 gimes me code sc620
SOURCE: copier problems
What model gestetner is it? There are different ways to rest it. What generation are you talking about? 10 years old or two days old model?? Need some more info. The problem may just needs to be rest, it most likely a fuser code to cold or to hot.
SOURCE: afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
SOURCE: Copier Only prints half the page
Sounds to me that the paper tray is set incorrectly. There is a dial on the back of the machine that needs to be set correctly once the paper tray guides are adjusted accordingly -particularly when running 8 1/2 x 11" (letter) size paper. It can be set to run either lengthwise, or laterally (portrait) make sure the dial is set to the proper setting on ALL trays. If the tray is set for lateral, for example, and the paper is installed lengthwise, the scanner only utilizes 8 1/2" in length rather than the full 11". Frequent jamming is also a common problem when making multiple copies, because the paper is not where the machine "expects" it to be. Also check that the LCD display reads the proper size / orientation after adjustment.
Hope this helps. Please rate solution :)
SOURCE: Gestetner 2822 error code e-5
i got a strait black thin line on left marging of paper. i think margin setting of my Gestetner 2822 has been changed. but i don't know how to fix this problem. (107-C, ???)
SOURCE: how much is gestetner 3222 worth
This machine is made by Ricoh and the same as a model Aficio 220. Pretty old and not worth much. If it runs and makes nice copies then $300 to $400. If it does not work or makes poor copies then next to nothing. I specialize in buying/selling used refurbished copiers and am very familiar with this model.
Good Luck and Thank You for using Fixya.
