Hitachi 43FWX20B 43" Rear Projection Television Logo
Anonymous Posted on Nov 08, 2012
It will work again temporarily if unplugged for a while.
Anonymous
Level 3:
Top Expert:
  • Hitachi Master 14,553 Answers
  • Posted on Nov 08, 2012
Anonymous
Hitachi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715356
Points
48227
The model listed almost never has this problem---if using a box (cable or sat etc) IT can cause this problem and in that case unplug the box for a while and power it back---it will try to reboot.
Also see if it does it or not when using a DVD etc connected to a rear input on the set--this will confirm the issue is related to tuner signal the set is using and may offer a way around the problem.
3answers
Can someone become a navy seal with a ged?
You can join the marine corps with a ged but as a tier 2 qualification there are less available enlistment slots
Jan 04, 2017 • Military
I cannot sign into my yahoo mail account.
The internet going out temporarily shouldn't have had an effect on yahoo as the two are not connected. Unplug your router for about 5 minutes then restart it, then boot the computer and attempt to sign into yahoo.
Gateway splash screen thats all I get
Try hitting the delete key over and over at boot up. If you can get to BIOS, you can disable the splash screen, and also make sure that the boot order is correct. Try to put your hard drive as first boot priority. Also, remove any CD's in the drives.
Good Luck.
www.cobaltflorida.com
3helpful
2answers
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
1helpful
Fd trinitron kv-27fs320
I think you may have a cold solder joint or burned loose connection somewhere in your power supply. Also maybe a crack in the circuit board. apparently when you moved the tv you "fixed" the problem temporarily. Stargazer
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
