Canon PowerShot SD870 IS Digital Camera Logo
Cheyanne Posted on Apr 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On My Canon PowerShot SD870 IS I Have a Silver Circle On My Screen After Dropping It At The Skatepark, Should I Replace The Entire Screen Or Can I Fix It On My Own Somehow?
I love this camera to death and there is a silver moon looking thing on my LCD screen. It's not on the pictures when I upload them on my computer but it is aggravating trying to show a friend a picture and you have a "black hole" in your screen. So please if anyone can help out and tell me if I need to buy a replacement screen or if I can just do something on my own in my own house simple and quick. Or if the camera is kinda just screwed and is going to have to stay that way and I need to buy another one. Thank you so much for reading and hopefully thank you for answering! (: Have a wonderful day :D
Lawrence Oravetz
Level 3:
  • Canon Master 10,558 Answers
  • Posted on Oct 31, 2017
Lawrence Oravetz
Canon Master
Level 3:
Answers
10558
Questions
Helped
2700297
Points
29284
A screen that far damaged cannot be repaired at home. Inquire about the cost of repairs on Canon's website, then decide whether to do the repair or scrap it.
5 Related Answers
Anonymous
  • 10594 Answers
  • Posted on Jul 24, 2009
SOURCE: Canon PowerShot A60~~~Viewing screen black/fuzzy won't take pict.
Its known problem of ccd imager in Canon A60 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Anonymous
  • Posted on Aug 01, 2009
SOURCE: Canon Powershot has black LCD screen
Dear All,
I solved my problem for Canon Ixus 750, i gently tap 3-4 times the camera in my sofa. I think the shuter was stack! Was stupid i know but is works perfect now!
Anonymous
  • Posted on Aug 14, 2009
SOURCE: Lens won't close.
I just found the culprit causing my camera to do the same. Under the battery door there is a post that hits a switch. That switch needs to be activated when the door is closed in order for it to work. Safety feature to allow someone not to put in a SD card while camera is on.
t00nz
CameraR
  • 4738 Answers
  • Posted on Dec 20, 2009
SOURCE: Camera's screen is black, but still takes pictures.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, try pressing the DISP button once with the camera turned on.
Anonymous
  • 3 Answers
  • Posted on Dec 23, 2009
SOURCE: Canon PowerShot SD870 IS camera - Lens Does Not Fully Retract
Canon SD870 IS. Lense Error. Would not retract on power-down. Lense error reported when retracting zoom.
Noticed the rectangular frame about the lens was rotated off center. Manually rotated (squared-up) the lens rectangle while repeatedly powering the camera on and off. Modulating the power allowed for easier rotation of the rectangular lens frame.
Once the lens frame was square with the body of the camera, the lens completely retracted on power-down, and also zoomed in/out without error.
Canon powershot SD870 IS. Once I switched to magnified image playback, I cannot cancel & return to single image playback. Have tried MENU and turning zoom button back.
Problem with firmware [software} ,Please update .
http://www.usa.canon.com/cusa/consumer?pageKeyCode=contactUsLanding
Yo can restart.Replace battery.
Problem with flash on Canon Powershot SD870 Digital Elf
There is a problem with the flash or flash charge circuit. It will need to be repaired and may cost about $ 100 if not under warranty,
Grey pixel blob appears on lcd screen on my canon powershot sd870
I'm not sure but I have the same thing on mine and the warranty just ended.
1helpful
Spot circle in screen
It’ a common problem on this model. The LCD screen is defective. Try to contact Canon for a free repair.
SD870 encountered water. Screen is now white. Does the screen need to be replaced or electronic components?
I know that when you take the ribbon cable off the LCD screen, and power the camera up, the screen is just white. It's probably that cable that came lose, or is not properly connecting. A good cleaning on the cable (behind the LCD screen) would fix it.
Blob of grey pixels overtaking the LCD screen on sd 870 canon
Canon will replace your LCD screen if under warranty. Same thing happened to mine. The blob got bigger and bigger.
White display screen
Sounds like the Backlight is working but the LCD is not. The first thing I would try is opening up the camera(if this is the sort of thing you are comfortable doing) and pulling out and then pushing in the LCD ribbon.
See this image for where the ribbon for the lcd connects (at least on a SD600).
http://3.bp.blogspot.com/_XmSxWfvnwsE/RlOsEjYjN5I/AAAAAAAAADs/0OuqTpB0GRc/s1600-h/plugin.jpg
Dissasembly guide for canon powershot (likely good for sd870 IS)
I have a refurbished Canon PowerShot SD870 IS which is not producing sound with video playback. I have adjusted the volume on the camera and on my computer - both just produce white noise. Is there an...
Touch the screen to pause playback and display the movie control panel. 2. Drag up across the screen to increase the volume. Touching the volume indicator displays the volume panel.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
