AUDIO NO PICTURE
AUDIO ON SCREEN BUT NO PICTURE CANT FIND HOW TO ALTER AUDIO ONLY ON MENU SCREEN
    Top Expert:
  • 14,553 Answers
No picture is your problem? No model number but a suggestion if a LCD set---in a very dark room look at the screen with a flashlight--see a faint image of any sort there?
Posted on Nov 08, 2012
SOURCE:
Picture does not fit screen on new Toshiba 4K TV with Charter Cable
get the screen menu up and alter the aspect ratio or pixel settings
Jul 20, 2018 | Toshiba Televison & Video
There is no picture on screen i can turn the power on and off thats all i can do i cant change the channel go to menu or anything else
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Oct 15, 2008 | Televison & Video
How do I alter the colour, brightness, and contrast?
Go to menu, go to screen settings or display settings. Should bring up the sharpness, contrast, color, brightness controls. Follow directions on screen to adjust. Hope this helps!
Jan 29, 2016 | Televison & Video
How do I get full screen on my samsung 45?
Those settings do not alter screen size, only the contrast/brightness. You need to go to the menu that alters 4:3, letterbox etc.
Sep 15, 2014 | Samsung Samasung 32inch UA-32EH5300 Smart...
MA-600 cash Register cant alter commercial message
Ok. So go inside the Menu.
- Press Enter or 1, it should select Messages
- Press Enter or 1, it should select Commercial Messages, and display the first line of the previous message.
- Press Enter and type the first line of your commercial message.
- Validate with Enter, and then (Enter again ?) or just start typing the second line.
- Validate with (double ?) Enter, then type the third line.
- Validate with (double ?) Enter. A long receipt should be printed display should return to Main Menu screen.
Mar 09, 2014 | Computers & Internet
Picture too dark on lcd hisense
get to the screen menu and alter the contrast to lighten up the screen. take it back to the repairer as it may be only be replaceable-not repairable.
May 11, 2013 | LG 42LC2D 42 in. LCD HDTV
The picture is too big for the screen. how can i make the picture match my screen size?
Posting the model number would make a response more valid but you need to go through the main menu selection and check to see if you can alter screen resolution or geometry there.Most sets offer different views such as 'Panorama,' 'Full screen,' etc.
Nov 21, 2011 | Sanyo Televison & Video
Loss of video signal from Onkyo TX SR 875
GO TO HARDWARE IN MENU SWITCH HDMI AUDIO OUT OFF, IF THIS DOSE NOT WORK MAKE SURE B SPEAKERS ARE NOT ON AS THIS PUTS THE MENU UP THE LEFT ,SOUNDS DAFT BUT IT DOES.IF YOU STILL HAVE PROBLEMS YOU HAVE A FAULT.
HOPE THIS HELPS.
CABLE GUY.
Jun 15, 2008 | Onkyo TX-SR605 Receiver
Cant see ps3 main menu
when in standby hold down the power button for over 4 seconds, it runs the optimal screen settings menu, hope this helps.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Hanspree 32" television
Hi, You may need to calibrate the screen size. That can be found in the menu under set up. Hope this helped. Jay
Jan 08, 2008 | Hannspree (K206-10U1-005) Television
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Ekse
