SOURCE: screen goes black while power button is on i turn
Common problem with is SONY 17" and the 19" are due to fail lamp assembly as shown in my pictures here which will be the worst case. You will need to check the other parts in the set first. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
You will need test lamps to verify.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
SOURCE: monitor keeps going black, turn power button off,
The problem is in the inverter board it is on the verge of failure, it is caused by bad capacitors in most cases and will eventually go. The board must be replaced or an attempt to repair the old one.
