I tried universal remots but it wont let me change to av
SOURCE: HOW CAN WE CHANGE TO AV ON HITACHI TV WITHOUT
Try this! Get into the menu and look for channel setup. See channel memory delete or save and add this to channel memory. Hope this works..I never repaired this model. This is only a suggestion.
SOURCE: change av without remote
get a universal remote if i wer you it may solve it but they do cost a bit ... look on the bright side you can tune those to any tv in the world =)
SOURCE: changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
SOURCE: hitachi C28W440N can't switch over AV channels no remote
have you tried buying a universal remote? you can get a decent one for £10 these days from any electrical store, such as curry's or maplins. it gives you a 3 digit code for the tv to link up with the remote and then you can switch over to av. some hitachi tv's also link up to av automatically if you connect your game station via scart socket (in the back of the tv) if you turn the tv off and link your wii up to the back and make sure the power is turned on before the tv is switched on, there's a chance the tv will auto detect the av channel. not all do but it's worth a try. hope this helps!
SOURCE: How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
