SOURCE: Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
SOURCE: i have a concert 2500...and
The power amp driving the dead speaker has gone bad or if you are lucky only a cable has fallen off. Open and inspect unit.
SOURCE: The pitch bend of my
The first thing is to verify that it is supposed to work with a particular performance. NOT ALL voices support modulation as well as pitch bend and with an arranger you can turn this feature on and off, usually in the utility functions and then save the setting for each performance/song. Read you user manual about modulation. On page 271 of your manual they show that the joystick is assignable. You have to assign the functions to the effect you want.
SOURCE: my ps60 has a high
Hello Brian, It could be a ground loop problem, I usually get something similar when connecting a laptop to an amplifier. You can purchase ground loop isolators from car hifi places which are used to take ground loop problems out of car audio systems. They are very cheap so maybe worth trying this first. I got one for £12. They have stereo RCA input/outputs and require no power.
Hopefully this is of help to you.
SOURCE: I have a new kaoss kp and when I put headphones in
The Mini KP is an effect processor primarily. Sound passes in and through either with or without processing and effecting. Due to this fact you must have an incoming signal to process, or you wont hear anything. However there are a few settings that act more like a synth and tone generator.To initiate an effect you must touch the pad and hold contact. There is a hold button on the lower left side facing down. If you hit this button while an effect is being created, then you can let go without the effect stopping. You can adjust the effect in real time as well. Out of the 99 presets if you have tried them all with absolutely no sound output, then the problem is physical and will need a repair man/woman.
No sound
• Are the other devices or headphones connected
correctly?
Check the connections. ........................................ (see p.6)
• Is the power of your amp or mixer turned on?
• Is the [MASTER LEVEL] knob raised?
• Is the Global mode Group 4 "MIDI Local" parameter
turned On?
Check the setting of this parameter.
• Are the bars of Drawbar 1 or 2 pulled out?
Pull out some of the bars.
Also check out this site and scroll down and do the "Factory reset" by holding down the buttons they say... AND please note that you have to hold them for a while during this.
