Try these links for the part
http://www.ebay.co.uk/itm/JANOME-OVERLOCKER-KNIFE-BLADE-UPPER-103-434D-234D-etc-/280899155711?pt=UK_CraftsCollect_SewingMachines_RL&hash=item4166e4f6ff
http://www.ebay.co.uk/itm/JANOME-OVERLOCKER-KNIFE-BLADE-LOWER-103-334D-134D-234D-304D-203-104-etc-/270833593318?pt=UK_CraftsCollect_SewingMachines_RL&hash=item3f0ef0abe6
SOURCE: mine is a simplicity 804 easy lock
Your knives may be blunt and need sharpening or replacement.
Check also if the knives are aligned properly. Remove the material and turn the handwheel slowly. The knives should pass each over like a pair of scissors and there should not be any cap between the blades.
If everything seems to be okay and it still does noet cut tne material, replacement is the only option.
SOURCE: Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
SOURCE: cutting knife adjustment
I have found this info...it mentions both threading and changing the knife width. I hope it is useful.
http://www.singerco.com/pdf/14SH654_threading.pdf
SOURCE: Need manual for Easy Lock 804 serger
Mine was destroyed in the floods a few weeks ago and I found a download and printable one at simplicityhomecare.com click on the download tab and select manuals and then under sergers chose your model. Good luck with your project.
SOURCE: manual for janome 234D serger
You can get one here - http://www.sewingmachinesplus.com/manual-j-234-en.php
Testimonial: "Quick & accurate response - I am very impressed. Thank you so much."
