Hi Erica,Try to shut it off, but if you can't, unplug it. Then try canceling it and plug it back in.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below: 1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab. 2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page. The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps. If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below: 1. Please open the "Solution center" again and go to the "Maintenance" Tab. 2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer. 3. Get a damp paper towel. 4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. 5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. 6. Next dab the cartridge on the towel to make sure that the ink is flowing. 7. Snap the cartridges back into the printer. 8. On your computer, select "Old Cartridge install." 9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
It is caused by waste ink at bottom plate of head. Print blank pages for cleaning itself. You can clean it by put wet tissue at bottom side of head. Turn off printer, move head to center. Put wet tissue at pad. Move head to parking position. Wait for 15 minutes. Print blank pages for checking.
wow..I could be the FIRST..I am impressed..NOT! check to see if there is ink, by blotting the print head on damp paper towel. otherwise..delete and reinstall the printer. could be a software problem.
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
