Sony Playstation 3 (PS3) Console Logo
Posted on Jan 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disc not spining in drive
Ps3 when a disc is put into drive it will not read it looks like the disc is not spining comes out in the same postion it was put in (motor not working ?)
  • 1 more comment
  • kates164 Jan 05, 2009
    We have the same problem Had no problems since purchase We were playing Call of Duty system froze (normal PS3 ) shut it down and next day nothing. You can hear it want to start But it does not.
  • mickbranch Jan 08, 2009
    made contact with sony and it is now being picked up next week by them for repair the guy was very helpful
  • Anonymous Jan 14, 2009
    Ps3 wont read my discs but i can see picture and everything and games arent that scratched either... anyone know how to fix it?
Anonymous
Level 2:
  • Expert 124 Answers
  • Posted on Jan 05, 2009
Anonymous
Expert
Level 2:
Answers
124
Questions
0
Helped
48935
Points
228
Sounds as the laser burnt out contact sony at 1800-345-7669 to get fixed or replaced
1helpful
When i put any kind of disk in my ps3 it tries to read the disk,but it just starts spining and stoping spining stoping ect...
Hi brady,
Yes the disc reading problem on the PS3 is massive!
Let me run through what is going on and how you can fix it:
Cause:
It is the laser that needs readjusting in order to fix this problem. The good news is that the drive will still work as long as you readjust the laser in most cases - so you don't need to replace the drive!
Solution:
You can send it in for Repair and they will fix it for you - although this will cost about $150 in a repair bill and you can expect to wait for about 4 weeks to get your console back.
Quicker Solution:
It is possible to fix the PS3 games reading error from home because as mentioned above all you are doing is readjusting the laser.
Now if you want to go down this route check out the reviews of the top guides and see what they offer first below:
Click Here For Reviews Of The Top PS3 Repair Guides.
Hope this helps!
tip
PS3 Optical Drive Failure.
Have you had your Ps3 drive tell you its just will not read?
Here are some major causes:
1. Dirty drive.
2. Motor not spinning the disc fast enough.
3. Bad optical laser.
Step 1
Listen for the drive does it spin up?
Listen for the read head.
Put a audio disc in does it play?
If a audio disc plays but not dvd,blueray, or game disc you got a bad laser.
I recommend you do the following:
1. Make sure you match up you serial number on your unit.
2. Purchase the whole kit not just the laser.
The kit looks like this:
ae2a243.jpgThe cost of these drives are from $50 to $120 respectively. I do not suggest Ebay I would suggest a Store that sales these with warranty intact. Do not get fouled by ebay scams.
Thanks for reading my tips. Please do leave a positive rating. Thanks for using fixya.com.
gps, home theater systems, home theater, tv repair, computer repair, laptop, repair, computer, laptops, home, computers, desktop, pc, parts,printers,refills,printhead,plunger,ps3 repair,ps3 drive
When the ps3 turns on the blue light saying a disc is in it comes on and refuses to accept any discs at all and when i do manage to get the blue light off and put in a disc it has to be forced in and the...
The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!.
Good luck.
2answers
1helpful
Ok...when I turn ON the PS3 it goes to main menu. When I insert disc, nothing change on screen and not even loadind or reading it. You can hear the disc spining,the drive pulls it in and thats it, I had...
what you have is a problem thats hard to diagnose.
the easiest thing you can try is to clean the lens.
along with checking the cables that connect your drive to the motherboard and etc..
if that didn't work you can try replacing the whole drive -- *NOTE* if you do change the drive make sure you buy the right type and also when u buy a new drive you will be getting the drive/moter only and not the control board that is attached underneath . you'll have to put your old control board onto the new drive
hopefully you get your drive working after these steps if not you will be getting into more complicated fixes.
this is one of the sites that i come across alot that fixes different ps3 problems
http://www.gophermods.com/index.php?l=product_detail&p=7
still if that didn't work you may need to replace couple of things on the drive board which can get very technical. very technical because in 2 ways.
1) your ic chip may be bad and you could try replacing that on your control board but that involves desoldering/soldering near many other component of the board. very trickly
2)if after you replaced the chip and it still didn't work you may have more than 1 problem on your control board in which case you just need a new control board but the thing is there is another chip that (the nand chip which holds the firmware of your ps3) is married to *********** board and without that chip your ps3 will not read/load/operate any of the disk or downloaded games on your ps3 hard drive. so just swapping the control board won't work. So you'll have to buy a new control board and swap out the nand chip. again very technical and not for a novice. even some repair shops send it off to do these fixes to a more specialist
if your ps3 is still under warranty its just best to send it off to sony and let them fix it for free. they cover your system for a year from the date of purchase. and you may or maynot get your original system back. check youtube for "replacing ic chip on ps3" or "replacing nand chip on ps3" you'll find that some people have actually fixed their systems.
2answers
Ps3 not reading disc..Please help
Do you see the little clock like icon in the top right corner of the screen when you first insert a disc the loading disc icon? if so then it could either just be the drive itself or a software issue in which case you can try a few things before replaceing the drive.
First just reset to factory default settings under system settings.
P.S. i assume its not reading any kind of disc if it isnt reading anything also double check to make sure the disc you are using are still good and not just really dirty or scratched. GIve us more info and what disc your trying to check so we can further help you out.
Justin
When i put the disk in it wont load so i can play it what is wrong you can hear it spining
The lens on the PS3 might have developed a fault which is preventing it from reading a disc. Try cleaning the lens with a dvd disc cleaner first.If you can hear is spinning then its most likely a lens fault.
3helpful
PS3 80GB not spinning DISC
the PS3 sony Blu-ray drive is very sensible..you should check the drive sensors first...
Could be a defective motor that´s not spining the disc...
would be very nice to test another blu-ray laser unit...connected with your blu-ray controller board...and you wil find if the logical blu-ray board is ok..or dead..So you must have a hardware to test and prove a second opinion !!!
Good Luck !!!
Cant play anything on my ps3
I have the exact same problem. I have been told that the optic of the console has stopped working. Is this true? Does anyone have the solution? Thank you
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
