I lost my manual and my black & decker 2030 iron says it is time to clean it. Please help Thank You
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
Fill with 50/50 sol'n of vinegar / water and soak 24 hrs. then turn on iron to hot then use steam function to empty reservoir then cool then fill water then repeat
My iron went into cleaning mode and I don't know how to stop it from doing this. I don't need to clean it now. How do I get it to stop?
did what was told to clean. did not work.
I misplaced the manual and the digital display reports the iron needs cleaning. Can you help?
My iron is starting to spit rust colored drops on my cloths. It needs to be cleaned but I lost the manual during a move. How do I clean my iron?
Thank you
Shirley Quinlan
[email protected]
Lost instructions on how to "clean" the iron...I have put the dial on clean and the message still appears...help! Love the iron!
It say clean in the window on the iron? How do I clean it?
cleaning mode on iron, how do I clean it? b
how to use the self clean
self cleaning sunbeam iron
Iron automatically switch to clen iron and it goes back to #1 setting. What do i need to doo to clean it?
Screen says clean on every setting. Lever goes to clean and sends out a lot of steam, but the note to clean does not go away. What do I do?
The cleaning option came on, and I can't find the manual. Tried turning the steam knob to "CLEAN", but nothing happened. Also, it is now leaking water and spotting the fabric. This iron is almost new.
Clean mode on black & decker d2030 iron
where do u put the water at in the black and decker iron ir34v
How do I clean my iron? Can I use vinegar and what is the process to clean the vents?
When i plug it in it makes a clicking sound
how do I put water in my iron?
