Casio PRG-40T-7 Pathfinder Logo
Anonymous Posted on Nov 06, 2012
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4799
Points
5
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.Casio PAG 40 I took it apart to replace bateries a - 11_14_2012_6_41_27_pm.jpg
  • Anonymous Dec 16, 2020
    Star answer - thank you soooo much - sorted!!
  • Anonymous Aug 17, 2021
    Wow! Thank you so much. I would have never found it if not for your q&a!!!
Fred Lawson
Level 1:
  • Contributor 3 Answers
  • Posted on May 31, 2014
Fred Lawson
Contributor
Level 1:
Answers
Questions
0
Helped
11243
Points
Vasil Filimon
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2014
Vasil Filimon
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3482
Points
I have a few questions for you guys:
1. Where do the 2 gold spring go?
2. I did a stupid thing when trying to replace the bateries. I accidentally brokken the soldering of the triple sensor (please see the attached picture). Do you have any idea of what kind of soldering i have to use?
Many thanks in advance :)
Casio PAG 40 I took it apart to replace bateries a - 598a275d-6a89-4970-b2c1-3ee37ff21ee8.jpg
  • 1 more comment
  • Kennynva T.
    Kennynva T. Apr 08, 2014
    Hi..if you dont fix your watch, I sure could use the small SILVER spring that goes on the outside of the back cover gasket, I have the two gold ones...thanks...
  • Florin Gogu
    Florin Gogu Jul 01, 2016
    I need a favor, do you have a better resolution picture? My batteries leak inside and corodate few paths. Need to remake the PCB but can not find anyware a good picture.
    Thank you!
  • Florin Gogu
    Your sensor can be saved soldering new wires from the triple sensor directly to PCB. You need a good soldering station and a good magnifier!
1 Related Answer
Anonymous
  • Posted on Feb 19, 2009
SOURCE: Changed dead batteries on PAG-40. Still one dead watch
There is a very small sticker with very small red print just adjacent to the battery compartment. This little sticker states "once batteries are replaced, you need to touch AC with tweezers". I did it with metal tweezers and the watch display came to life. Good luck!
1helpful
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
1helpful
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
1helpful
Found small spring when changing battery
This happened because the COIL SPRING was lost during the battery change. This happens quite often to DIYers, as they do not know how the watch is built and the coil spring itself is very small, so, it's easy to loose it without even noticing it. Coil spring transmits electrical signals/vibrations from watch's movement to the quartz membrane attached inside case back. Now you have to find yours or need to visit your nearest watch repair shop and ask for the new one to be fitted..
1helpful
Casio dw-290-t, springs came out when changing battery, I know wher 1 goes not the other?
The smaller spring is steel with gold plating. It goes into a hole that is near the outside diameter of the battery. You must remove the outer steel retainer to see the hole. Leave the other parts assembled. They will be loose at this point. When you look inside the hole you should see a gold bottom which is really a contact on the board. Insert the spring with the smaller diameter end into the hole. If you have the correct hole then the larger end of the spring will fit just perfectly. Assemble the outer steel retainer. Finish assembly.
Next time you replace the battery only remove the battery strap and leave the other parts intact. Good luck.
Jun 22, 2012 • Watches
12helpful
5answers
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
1helpful
Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
17helpful
8answers
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
