I NEED BECAUSE WHEN I BUY MY CAR THEAR DON,T GIVE TO ME CODE
You will have to contact the person that you got the car from, If it is a after market system in it, To get the code from them, If they rember the code they made up for it, Any after market system, The owner can (Pick) His own personal code for it, If it is a factory system,You can get the code from the dealer, It is done that way,Because if it is stollen,That if some one try to install it,There is no possible way to get it to work with out known the code the person put into it,
SOURCE: code siemens vdo cdr2005 sn:13 122 932
i have lost my code due to battery going flat siemens vdo cdr 2005
SOURCE: my siemens VDO, cdr 500 car stereo has been locked
These CDR500 codes are only available from the Main Dealer or Radio Decoding Service
Not available for free from anywhere on the Internet
Sorry
SOURCE: siemens car radio gm020553571099 do u have code
Unfortunately the majority
of SIEMENS/VDO codes (including your CDR2005) will
NOT be available for free (or
cheap) from anywhere on the Internet as
access is required to the original factory database…which is not commercially
available..
Try your Main Dealer or a
Decoding Service or your local Car Radio / Audio Shop (who are normally the
cheapest option) who will connect it to a laptop to
read/recode the memory chip (EEPROM)
SOURCE: lost radio code on vauxhall vectra VDO CDR500 radio``
Unfortunately CDR500 codes (made by VDO or DELCO) are only available from the Main Dealer or by using a Radio Decoding Service
Testimonial: "thanks v much for help.contact dealer at some point next week.cheers"
SOURCE: Need code for siemens vdo 330886636 no 24 469 302
I NEED RADIO CODE FOR SIEMENS VDO 330886636. No.13 138 246. GM020521690276.PLEASE HELP ME.THANKS!
