SOURCE: 2006 Jeep Commander Intermittent Starting Problems
Common problem in snow country where salt water can corrode starter parking gate wire connection at started tab. Just cleanthe connector and tab, coat in dielectric grease, problem solved in 15 minutes!
SOURCE: 2008 Jeep Compass won't start. Lights are bright
I had same prob with Grand Cherokee - no rhyme nor reason as to when, where or why it wouldn't start. After two new starters the shop finally found a starter wire/cable that was corroded on the inside. Mech' could move it back and forth and it would / would not start. Changed cable six months ago - no problems since. Hope it helps.
SOURCE: 2008 Jeep Commander with 5.8l Hemi problems with instrument panel
Have shop run an OHM test on your transmission sensors -- then have them replaced and rerun the OHM test. -- it's more than likely an input speed sensor that is not working properly and telling the jeep to go into "limp mode" hence your speed isn't changing but it can't read the actual speed.
SOURCE: 2007 jeep commander rocky mountain no sound from radio
take it to the dealer. they will put a new radio in it if you have under 36000 miles
SOURCE: 2003 Q45 Electrical Problem: Radio/Navigation screen goes blank
YOU HAVE A MODULE PROBLEM THAT IS SHORTING OUT AND TRIGGERING ACCESSORIES CIRCUIT HAVE IT CHECK ''CAN SHORT CIRCUIT AND CAUSE FIRE''
