Started getting this message at start up of pc:
spoolsv.exe application error "0x7c9137e" reference memory at 0X00000000 could not be read
can't print, no pdf, outlook hangs after a short usage, some client programs will not load.
Any suggestions?
Thanks,
Gary
The Spoolsv.exe executable file is responsible for handling the printing process on a Microsoft Windows system. Although this process is not crucial to run your Windows system, you must not terminate it until you think that it is causing problems on the system.
To fix spoolsv.exe application error, you will have to remove these files from the system. To do this, perform the following steps on your Windows XP computer:
Note: If you are unable to delete the files in Normal Mode, then you may have to restart your computer in Safe Mode to delete the files. To start your PC in Safe Mode, press F8 at system restart and then select the Safe Mode option from Windows Advanced Options Menu.
If deleting the files does not rectify the problem, you must perform a System Restore and rollback your system to the time prior to when the error started appearing on your computer.
*Your vote is highly be appreciated. Thanks in advance. Let me know if this fix your problem.
Best regards
I faced the same problem and I got a resolution which worked from:http://www.microsoftsupportchat.com/blog...
