Radio Communications Logo
lurch cb Posted on Nov 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Big stick cb antenna wont recieve - Radio Communications
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Nov 06, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715292
Points
48227
Have the radio tested first on a dummy load--if ok check the connector on the antenna--Big Stick antennas if old can break inside but a SWR check should reveal if a open antenna or a shorted one----you with a ohm meter should get a reading across the center pin to the threaded part of something like 50 ohms---either the antenna, coax or even the radio....
2 Related Answers
Anonymous
  • 105 Answers
  • Posted on Nov 11, 2009
SOURCE: CB radio recieves but does not transmit.
I would recommend that you put an swr meter (CLICK HERE) between the radio and the antenna to see if your radio is transmitting anything at all. Also, it will check to see if your radio is correctly matched to your antenna. If your antenna is not matched correctly it will fail to transmit correctly.
anymhz
AnyMHz.com
  • 500 Answers
  • Posted on Jul 20, 2011
SOURCE: I purchased a Midland 1001z
Vibrations on the small cb's make the internal circuit boards come loose and its intermitted or will not RX or TX.. Check the antenna with another cb. using an SWR METER.. or have someone check it.. SWR should be free if you take it to them.. to check.. Make sure the antenna, mounts, and coax are ok.. if soo then its in the cb itself .. Email us if you need more help or need the radio looked at, the post office has flat rate boxes cheap nowadays. were in Temple, TX at the CB SHop.
2answers
What antenna for what cb
bad ground/bad swr/any antenna will work on any CB radio as long as its an antenna for the CB range.
Dont go or recieve more then half a mile
Check the SWR on the antenna system.
I purchased a Midland 1001z in the fall of '09 and installed it on my boat. I is mated to the existing Shakespear 8' CB antenna. The CB worked great last summer while boating with my brother and...
Cb has power but no squelch,can't recieve or transmit
Begin with
  • Volume knob 12 o'clock position
  • Squelch knob full counter clockwise
  • RF gain knob full clockwise
  • Pa/CB switch to CB
  • Mic plugged in
  • Check coax and antenna connections.
  • Make sure your antenna gommet/insulator is installed correctly or it will directed gound. Treat antenna shaft as it is the positive portion of circuit.
If you have another CB check the antenna system with that rig. To verify it is a radio issue. Then dig deeper Microphone, PLL chip, Audio chip etc.
I can recieve on my CB but cannot transmit
sounds like thats a regular antenna wire. cb radio normally have a pl259 plug. and you need a propper cb antenna not one that has am/fm plug. cb antennas require tuning using a SWR meter.
Cobra 29 ltd classic cb not transmitting
Check the ground. Make sure its grounded well on bare metal. To see if the ground is bad, or not making good connection, disconnect the antenna and turn it on. if it does not power up, that means your ground is bad, and it was grounding only through the antenna.
Make sure not to key up with out the antenna connected.
Cant transmit out
Not really enough info to help you, but you MUST check the SWR of your antenna system. I've seen many cases where the antenna studs were incorrectly installed, shorting the antennas to ground. Also, make sure the Dynamike control on the CB radio is turned fully clockwise.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
