Comdial Vertical Edge Vw-e100-24 Display Phone 100 Logo
Posted on Nov 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the menu button on the vertical edge 100
How to change time on vertical edge 100
Anonymous
Level 2:
  • Expert 32 Answers
  • Posted on Nov 05, 2012
Anonymous
Expert
Level 2:
Answers
32
Questions
Helped
4792
Points
104
  • Gary Hendershot
    Gary Hendershot Jan 09, 2018
    Link doesn't work. PDF removed.
Can vertical lines that start out in the middle of the screen be fixed
Generally no, this means that the connections from the edge of the lcd are failing.
Edges of picture being cut off. Is there something we can do to adjust it?
Have you tried changing the aspect ratio? On your remote there should be a button labled aspect. Otherwise you'll need to access the service menu and change the vertical height and horizontal width.
I want to adjust my screen , its is streching vertically Please help
Look for "buttons" on the bottom-front or bottom-edge of the monitor.
One button will activate the OSD ("On Screen Display). Through the OSD, you can change the "vertical size" and "vertical position" of the display.
1helpful
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
3helpful
Track ball does not allow east scrolling; it only allows west, north, or south scrolling
Try to change the horizontal sensitivity and vertical sensitivity of the trackball to 100%,to do this follow the below mentioned steps
1)press menu
2)select option icon
3)scroll down and select screen/keyboard option
4)select horizontal sensitivity and change it to 100%
5) select vertical sensitivity and change to 100%
6) press menu button and select save
Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
2answers
For monitor display setting
Good evening Paresh this is viswanath Don't worry I can salove UR problem
First U go to Open Menu & go to Zoom option, select Zoom Function and press 30 sec
sercice manual is open Adjest UR settings & save it,turn of ur monitor.
3answers
APEX 27" screen settings - service manual
Just click below for the manual;
[PDF] AT M C T
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Adjust the date on the i70
Hey Mat,
You can find your product manual here:
http://www.samsungcamera.com/popup/download.asp?prol_uid=4148&prj_uid=733
You'll find once you download the manual's pdf, it'll be on page 20 of the pdf manual. The sample is below, but it's much clearer on the pdf manual. Best of Luck!
When Using the Camera for the First Time : Setting up the Date / Time and Language
When the camera is turned on for the first time, a menu will be displayed
in the LCD monitor to set date, time and language. This menu will not be
displayed again after setting up the date, time and language. Set up the
date, time and language before using this camera.
■ Setting up the language
1. Press the [Language] menu button.
2. Select a desired language by pressing the
vertical smart button.
■ Setting up the date, time and date type
1. Press the [Date & Time] menu button.
2. Select a desired date type by pressing the
3. To change the date, select the [2008/01/01]
menu and press the vertical smart button.
4. To select Year / Month / Day and Hour :
Minute, press the horizontal smart button.
To change the numbers, press the vertical
smart button.London
● You can select any one of 22 languages. These are listed below :
- English, Korean, French, German, Spanish, Italian, S.Chinese,
T.Chinese, Japanese, Russian, Portuguese, Dutch, Danish,
Swedish, Finnish, Thai, Bahasa (Malay / Indonesian), Arabic,
Polish, Hungarian, Czech and Turkish.
● Even if the camera is restarted, the language setting will be
maintained.
HD distortion Problems
have a tech change your your vertical ic.there is also 1mf 50v cap that is located in the vertical circuit that usually goes bad have it change.good luck.
Top Comdial Lands Phones Experts
k24674
ADMIN Andrew
ADMIN Andrew
omonat at engineer...
Level 1 Expert
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
