Every time i try to open a text message from one particular contact, my phone locks up and i have to pop the battery out, replace it and power my phone on again. any other texts from other contacts open fine, but as soon as i switch to the folder of this one contact, it does the same thing.
SOURCE: deleting lg rumor text message contacts
Take a picture and select it to send. Under Options on the camera screen, it will populate the screen to send. if you go to your recent list (last option), it will bring up folks you've TEXT. Select the names you want to remove, then Options. You can delete the contacts here, which removes them from your recent list, but not your "hard contact" list in the main phone.
SOURCE: saving sms texts from lg tu550
The solution is a bit convoluted and tedious, but it works.
SMS format messages can't be e-mailed. Therefore, they need to be converted to Multi-Media format by inserting an image, sound file, video file, but not a symbol, after which they can be e-mailed.
However, original SMS transmission details including recipient/source, date and time do not appear to be preserved when the SMS is first prepared for forwarding and attaching a MM file, prior to sending as an e-mail. Therefore, either a manual record of the original SMS details can be kept, or the forwarding SMS edited with those details and the MM file insert, prior to e-mailing.
SOURCE: my LG lotus won't turn on.
Mine started doing the same thing yesterday. In doing a bit of research I found on the LG support forums that the phone is probably fried. The good news is that it's covered under the 1 year manufacturers warrenty and can be returned to the sprint store, or your carrier and they will replace it on site. I've already talked to Sprint and they said as long as there's no water damage or other visable signs of shock that would have caused the damage that they'll provide me with a new phone. This was a huge relief to me, I loved this phone before it went batty and really can't afford a new one.
Hope it works out for you as well.
SOURCE: cannot remove number in the sent IM menu of the LG Rumour
Click on messaging icon from main menu.
Click send message.
Instead of clicking text message click on pic/video message.
then you have 4 options TO: CONTACTS , TO Mobile#, To Email, And finally To Recent lict. Click on recent list and checkmark all the numbers you want deleted then click options bottom right corner then click delete.....
All finished hope this helps.
Steps to Reset Settings
This resets the phone to factory default settings.
