Stanley 77 115 Intellisensor Plus Stud Sensor Logo
Anonymous Posted on Nov 05, 2012
Stanley intellisensor 77-110 schematics - Stanley 77 115 Intellisensor Plus Stud Sensor
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Red light would not go out and beep would not stop when moving finder across wall.
I had this problem as well. The solution was to replace the 9 volt battery that it runs on. The beep was much louder and it calibrated correctly. Apparently the old battery was enough to make the beeping sound but not strong enough to emit the energy required to penetrate the drywall.
2helpful
How to operate the 077445, I have lost instructions
You can view a manual for this product at
http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-552007645425770921/!DOWNLOAD?entryid=156229&attachid=19306
Or visit http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-8342273085529316507/front_page!PAGETYPE?category=2 and type 77-115 into the search box.
2helpful
Please advise me to how to use and how it work as there are no instructions in english in leaflets enclosed in pack
Hold the unit flat on the wall. Press and hold the side button (you will hear one short beep). Holding it to the wall, slide the sensor left or right, when you get near a wall stud, the lights will begin lighting up, when centered on the stud, the top light will be lit and it will beep continuously.
Need schematic for antique Stanley Handyman Yankee Drill No 233H
I don't think Stanley has schematics on their web site but they do have parts. I'd contact them and see if they can furnish the info you need. See this link: http://www.stanleytoolparts.com/yankeeratcheting.html
4helpful
How to operate the Stanley Stud Finder
Hi Gene,
  • Place the unit flat against the wall.
  • Press and hold the button.
  • The LED will come on for a second or two then go out.
  • Slowly move the unit laterally until the LEDs come on again.
  • When they top out, that is the beginning of the stud.
  • When they start to go back down, that is the end of the stud.
That's about it..
Best regards
Mike
1helpful
2answers
How does it work?
Here are instructions to get the manual for this sensor:
Go to Stanley Support
Click on the "Knowledge Base" link.
When the window opens type 77 115 in the search block and click on "Search". (NOTE: Leave a space between 77 and 115 or this will not work.)
The Instruction manual should be on top of the list that appears.
Click on the link under the "Article Name". (77-115 Intellisensor Plus Instructions)
On the next window click on the small icon under "Format". That will open up a PDF file for you. Save it to your computer for future use.
If you have any trouble, just comment back.
Thanks for using Fixya.
2helpful
Dont know how to use
Go to:
Stanley Support
Top Stanley Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
