Washing Machines Logo
mark brazier Posted on Nov 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint fdw60 4th & 6th lights flashing
Richard Roth
Level 3:
Top Expert:
  • Washing Mach... Master 9,472 Answers
  • Posted on Nov 05, 2012
Richard Roth
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628896
Points
28464
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Nov 05, 2012 • Dishwashers
FAST 40 DEGREE, DELICATE 50 DEGREES & SALT REFILL LIGHTS ARE FLASHING, WHAT DOES THIS MEAN?
40 and 50 degree lights are flashing on my free standing fdw60 hotpoint dish washer
5helpful
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
1helpful
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Error light flashing - wash & drying lights flashing.
My machine would not always set properly and various lights went on and off without reason or stayed flickering. I phoned Hotpoint as like you my warranty was finished. They told me to switch off the machine and unplug at the mains. Leave for 10 minutes then plug back in and switch on. It re-booted the control panel and last night I was able to set it properly. If it doesnt work for you I suggest you phone Hotpoint customer service (number of website) and ask if there is anything else you can do to solve the problem yourself before you pay for another service call. Failing that buy a new one!!
Top Washing Machines Experts
john h
