The lines have gotten worse and they are around the middle and to the left. the ones in the middle have gotten thicker and the ones to the left are two thin ones.
Lines can be caused by a number or things: bad main board (control) which is rare, bad or loose plugs or solder connections.
The worst case is the issue (connections etc) can also be inside the display panel (PDP or plasma display panel) where they cannot be got at.
Parts for brand listed are not real easy to find in some cases.
SOURCE: insignia 32-lcd black screen and thin colored lines vertically
Most likly the signal connector is loose or dirty. (input) this would cause the red, gree, blue or a combination to not be connected.
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
SOURCE: i have a 8 in. black line going top to bottom left 50 in.insignia
I would recommend scheduling a technician for diagnostic and repairs. In-home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
