My heater coils heat up but the fan will not come on it is an intertherm e2eb-017ha electric furnace
Could be the fan relay is bad. or the run capacitor. if these check good. you may have a bad heat sequencer. hard to tell, if you thave a/c you can turn thermostat fan swith to on and if blower comes on then relay and capacitor should be ok. some units have two or three heat sequencers 1 controls fan and the others control heat strips hopefully this helps good luck
HAVE TURNED THE FAN ON MANUAL AT THE THERMOSTAT AND WORKS FINE WHICH SEQUENCER CONTROLS THE FAN
