I have a brand new hoover wind tunnel. while in the middle of vacuming it just turned off and now won't turn on agian.
Ideas
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Shuts off wont come on again.
same problem, will turn off after 5 minutes of cleaning. Filters are clean, brushes are good. Let unit set for 30 or minutes and back it comes for another 5 moinutes, A sorty machine.
