Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Cannot attach toe plate - Frigidaire FRT21H8 Top Freezer Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Hello - To remove the toe grille you will need to have the doors of the refrigerator open, the grille simply snaps into place. Remove the right side first and then the left, as the water line is on that side. When replacing follow the steps in reverse.
Posted on Nov 05, 2012
Testimonial: "Very helpful, thank you. I hadn't tried it with the door open and that made all the difference, though it still took a rubber mallet - tight fit! Thanks again!"
What is the toe panel on a washing machine
A toe panel is also called a kick panel or kick strip or base plate. It's the lower piece on older model washers and dryers, although you don't see it much on newer units because the entire front is one piece and has to be removed as an entire unit.
Apr 29, 2017 | Washing Machines
How do I remove bottom grill on refridgerator
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The bottom grill or toe plate is held on in one of two standard ways.
Some toe plates are held on with two screws, one at each end. If you do not see any screws then the toe plate is held on with clips, one at each end. Pull straight back firmly at each end of the toe plate to remove.
Feb 10, 2015 | Refrigerators
I have kenmore freestanding ice machine. Water flow fine, will not cool. Can I add free on and if so where
You do not add freon to these units, they are sealed, no access ports installed from the manufacture. If you are actually low on freon than you have a leak and will just end up in the same place you are now. Some things to note since you have not posted a model number. Does the water come into the reservoir when you first turn it on? Does the water circulate over the freeze plate shortly after it's done filling? Is your condenser coil on the bottom behind the toe plate completely clean of dust? With the toe plate off are all of the components running, like the compressor, and fan motor after your fill time has expired? Please add a complete model number from the sticker on the unit for better advice. Pleazer Appliance...
May 07, 2014 | Kenmore 51lb. Clear Ice Maker
How to install toe stop for dw 5000 pedal?
I believe, the toe stop sits at the very top of the foot board, with the flanged back edge resting in a groove at the top of the footboard. There is a screw that holds a chain to top of the footboard and connects the chain to the footboard. I think you simply replace the factory screw with the longer toe stop bolt and nut. The bottom bit of the chain that connects to the footboard has a small flanged housing. This housing on the chain is designed to hold the nut in place as you screw in the new toe stop plate bold. It is super easy . . . and I think that about sums it up. You just unscrew the chain off the footboard, and replace the toe plate so it fits, and reattach the chain to the footboard with the toe plate bolt and nut.
Dec 25, 2012 | Drum Workshop DW SP50TS Toe Stop For 5000...
I am able to access the back of the condenser coil to clean it but cannot get to the front of it. Using a flashlight from the front I can see that the coil is totally caked with dust. How can I get to the...
get a shop vac and a condenser coil brush,you can buy it at any appliance or hardware store,you stick the brush into the coil and the dust sticks to it or falls apart onto the floor or i use a shop vac,one end vacs the other end blows,i vac up as much as i can and then blow the rest off of the coil,you can remove the bottom back panel and blow it to the back wall and then vac up the dust that blows to the back
Feb 25, 2011 | GE GSL25JFPBS Side by Side Refrigerator
How do I change the water filter for ASD2522WRS
Your water filter is located underneath the freezer door, in the toe plate grille. you will see a knob, turn it counter clockwise one quarter turn. Sometimes its easier if you remove the toe plate grill first. Remove the filter from the housing, then remove the knob from the filter, place the knob on the new filter, remove the red cap on the other end, and with the "handle" of the knob pointing up and down, insert the filter, and twist it clockwise one quarter turn. Replace the toe grill if you removed it
Nov 09, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have a Kenmore Adavantage Dryer - Model #110-96588210. Dryer runs but no heat at any temperature setting. I have the toe plate off and looking for the thermal fuse that is connected to two blue wires...
the only way you can check if it is ok is to use a tester or continuity tester, it should have a resistance when you check it. you cannot just concluded by just looking at it, fuse are pretty quite decieving.
Nov 08, 2009 | Kenmore Dryers
Where can I find the model number on my Kenmore side by side refrigerator
it should be right inside the refer
open the door look up
it might be on the upper right
upper left
middle on the ceiling
yes on the cieling
if its an older one
pull off the toe kick
it will be on a plate on the unit behind the toe kick
Oct 04, 2009 | Refrigerators
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
525 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
