SOURCE: driver for microsoft virtual wifi miniport adapter
Here is the download link for Microsoft Virtual WIFI MiniPort Adapter
ftp://ftp.research.microsoft.com/downloads/994abd5f-53d1-4dba-a9d8-8ba1dcccead7/MSRMesh-VirtualWIFI.MSI
I'm giving you the link as you want to download the driver, but still your WiFi will work without Microsoft Virtual WIFI MiniPort Adapter driver.
It's just a New Technology wihich comes with Windows 7. It's function is two connect more than one Wi-Fi or hot Spot connection at the same time.
Rate this solution.
SOURCE: windows cannot load the driver for microsoft
Google your problem, lots of help available.
Check this http://social.technet.microsoft.com/Forums/en-US/w7itprohardware/thread/566a63d9-a5f8-4210-a5ee-48411425f5c3
SOURCE: do i need to update
No need. You just have to make sure that your 2 network adapters are installed correctly like the one for LAN and the integrated wireless adapter.
SOURCE: microsoft virtual wifi miniport adapter
Hi
take a look here you may find what you are looking for please click on drop down boxes to select your make and mode then os
http://support.gateway.com/us/en/emac/product/default.aspx?tab=2
then scroll down or type in search box what you are looking for
good luck
also you could look for a scanner some websites use a scanner to scan your laptop to offer you some drivers or updates but you will have to go up top of your screen and allow the scanner to load if you want to use it. it is good practise to use the scanner when its available
good luck
SOURCE: Microsoft Virtual WiFi Miniport Adapter
