I did have Error: Data is not align 16k! when i start up my ds.
What I did was..
All the files you need are at
www.neoflash.com.
Your need (MK5) v1.45 which is in the download section.
Some of the nds roms do needed unraring before putting on memory card. They should be in .nds format etc.
The files you need are...
DSYSTEM (Entire Folder And Contents
MK5_2Mbit_test_v5.nds
MK5_PassMe.nds
xmenu.dat
When you have these files THEN you can format by...
Please insert both cards in to the DS and power up, tap the screen to continue as you would for any normal game.
You will then come to the menu "USB Mode" and "Menu Mode"
Instead of selecting one please press and hold the "select button" on the DS then tap "start"
Select "Quick Format"
Once complete restart the DS, you will have to tap the screen as above and this time select" USB MODE"
By formatting the menu file will have been deleted from internal Memory and will need replacing with the files. downloaded from neoflash.com
(MK5) v1.45
MK5_PassMe.nds
xmenu.dat
(Drag and drop these files only)
Now your new system is ready, restart NDS and enjoy
Will fix almost all problems with DS Firecard and applies to both 8 and 16gbit.
