I ran the dishwasher yesterday. When I unloaded the lights were still on and the control panel didn't function.
SOURCE: PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
SOURCE: KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
SOURCE: KUDS25SHWH1 Kitchenaid Dishwasher Control Panel Only CANCEL light on
I bought a control board for $127.00 figuring that was the problem but it wasn't. I called an appliance guy who came out and said its the touchpad that needs to be replaced. I ordered the touchpad ($325) since I already have to much invested in this dishwasher. I paid $1200 for it 8 years ago and its really a great dishwasher. My appliance confirmed that if it was the fuse-ling that you would not have any lights on.
