The ceramic glass cook top is broken but no other parts have been damaged
Hi stormsdestin - Thank you for your post! The electric range, model number FEF353BFW is recommended to used warm soapy water to clean the electric cook top. If your cook top is broken or damaged, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. However, if you are requesting information on what kind of cook top repair creme may be use I would personally suggest contacting the manufacturer directly.
Are you sure your top is not one of those that have the Pyrex top. Some cookers have this to save the works against such an incident.
Fit split ceramic try same color heat resistant epoxy
