Question about Broderbund Printmaster Silver 12.0
Disc won't install
Disc seems to be corrupted-won't install on computer
    New Friend:
    Problem Solver:
  • 16 Answers
It may just not work on your computer. not all games or disks work on all computers
Posted on Nov 03, 2012
SOURCE:
Disc won't play
May not have been finalized properly and is therefore corrupt.
Apr 19, 2013 | Sony Handycam DCR-DVD850 DVD Hybrid...
My game won't work because it need's a update
This can be a fairly easy fix if done correctly. I am a repair tech in Ga. and recently ran into this little trickster of a problem. Try this,,,
Power the console off. Press eject and insert a DIFFERENT game (I always use the Halo 4 install disc)
Your system is looking for a required update but it seems the disc you are using may be corrupt or damaged.
After trying a different game disc it should work out for ya. If not you can try this method.
Eject any discs. Power system off.
Find a 1-2GB USP flash drive and follow the instructions on this microsoft website...
http://support.xbox.com/en-US/xbox-360/system-updates/system-updates-info
If you still have problems you can call 1-800-4MYXBOX
I’m happy to help further over the phone at https://www.6ya.com/expert/jay_25de800b00457e27
Mar 16, 2013 | Microsoft Xbox Video Game Consoles & Games
Why won't this install on my laptop?
If you are using windows, go into "My Computer" and look for your cd/dvd drive . Right click , choose explore and double click on any file that looks like "install" or "setup"
Nov 10, 2012 | Mindscape PrintMaster Premier 7.0
Msi a6200 won't read ANY discs lately.....not sure what or where to start any info would help.
It seems like you have a hardware issue, clean lens with rubbing alcohol and a Q-Tip gently, allow several minutes to dry, if no change, remove screw from the bottom where the drive is and take it out, now reseat it back in place, if still the same go to www.ebay.com Type: make and model of laptop, refine search to cd/dvd driver.
May 10, 2012 | MSI A6200206US PC Notebook
My medion akoya laptop won't load past intel screen
This is a hard drive issue or windows have corrupt files, if you have the installation disc try and reload the operational system, if no change! have the hardware checked out at a computer repair store.
Apr 08, 2012 | Medion Computers & Internet
I have an Acer Aspire AM3910-E2512. I moved recently and now the computer won't boot up. It keeps trying to 'repair disc' but it ges for hours. I opened the side and there is one set of wires that
That is typical to have extra power connectors not plugged in. The PSU will have extra connectors in case you add other peripherals. Most likely you just have a corrupted operating system. A system restore if you have the disc would be the easiest way to repair this. However you will lose your data. If you have the restore disc they typically will have some repair utilities to try and fix the corruption.
Nov 10, 2011 | Acer Computers & Internet
Can i use my emachine recovery disk on my gateway after i install a new hard drive on my gateway?
No, you can't. (Well, it might be possible, but very unlikely, that it would work.) Recovery discs are made for specific machines. There are a couple of reasons why the discs for one system can't be used for another brand or model.
In addition to installing the operating system (Windows), recovery discs also include drivers for the machine's included hardware (video, sound, media card slots, etc.). The drivers on the recovery disc for an eMachines system won't have what a Gateway system needs, unless they were built using exactly the same motherboard and other parts, which would be quite unusual. If wrong hardware drivers are installed, Windows may not start and give you the famous "blue screen of death". Or Windows will start, then begin finding new hardware and asking you for drivers you won't have (although you could find them at the Gateway website). The discs also include the applications the manufacturer preloaded on the system. Some of these may not work and cause problems because of the hardware differences (a sound control program with the wrong sound hardware, for instance).
The other reason is that a restore disc also includes information that gets placed into Windows so the system comes up already activated and ready to go. Activation is based on information about the hardware configuration of the system, and yours won't be correct. Windows will see the this and you'll need to activate manually. If the Windows version on the eMachines recovery disc isn't exactly the same as the one on the Gateway, the product key on the computer won't work when you try activation.
Rather than try using the wrong recovery disc, see if you can borrow or download the installation disc for the Windows version specified on the product key sticker on the Gateway. Then you can do a clean new Windows installation and activate it using the product key. You can find the drivers your computer needs at Gateway's website as I mentioned before. It's more work than just running the recovery disc, but it will work. This does mean the system won't have any of the preloaded applications originally on the computer when you're finished. But this is not a bad thing.
Much of the preloaded stuff on a new computer is often called "bloatware", which you really don't need. It just slows the computer down, uses up Windows resources, and may be gathering information and sending it to sites behind your back. You can find good free programs to do anything originally installed and install only what you really need and want. Here are a few suggestions to get you started:
CD/DVD burning: CDBurnerXP
Antivirus: AVG, Avast!
Audio processing: Audacity
Image processing: GIMP
Office suite: OpenOffice
Good luck getting the system back up and running. Thanks for using Fixya!
Jun 30, 2011 | Gateway GT5670 Desktop PC
Installation disc will not work
You don't need the Olympus software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 29, 2010 | Olympus FE-210 Digital Camera
Broderbund Printmaster Silver 12.0 Logo
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
