Expert
- Posted on Dec 02, 2012
Re: Please can u show me how to change the time on this...
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
Sponsored Links
3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
