Question about E-Machines T3256 PC Desktop
T3256 needs ethernet driver
I wiped out hard drive to fix problem and reinstalled Windows XP
Now it will not connect to internet because missing ethernet driver
Before I wiped out hard drive i had called gateway and they said i need needed recovery disk which i could not find now i realize it was probably already on the hard drive and i could have recovered but it's too late now
  • 1 more comment
  • shaow20 Feb 15, 2009
    same problem
  • Anonymous May 01, 2009
    i ran my recovery disk for my E Machine (T3256) a week ago so everything was erased i believe because when i tried to connect to my internet provider, my PC doesn't work or doesn't connect to include my local LAN connection.Can you help me on this?maybe sound and video cards were also erased.Please help me on this and Thank you in advance for your timt and effort on reading and for everything.sayonara..
  • jasonkozd110
    jasonkozd110 Dec 03, 2012
    FOUND: LAN drivers for eMachines T3256: This is a unified driver for the nVIDIA chipset. The ethernet driver is on-board; i.e., all on one chip:http://www.nvidia.com/object/nforce_udp_...
  • 16 Answers
Dear Cedrich,
I found an "unofficial" e-machines website for you: http://www.e4allupgraders.info/
And the following is a link to your Ethernet driver:
http://www.e4allupgraders.info/dir3/files/drivers/lan/AU31_Ethernet_xp2k.zip
Here is the page for your particular model:
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31_downloads.shtml
If you need any further assistance, please request it,
Jem
Posted on Jan 04, 2009
  • shi_nas Sep 13, 2010
    wow works fucken great!!! Thank you so much... mundosworld.com
  • dcrr Nov 03, 2010
    Thanks, it was a 1 shot deal and works 100% "The Bug"
    New Friend:
FOUND: Ethernet driver for eMachines T3256: http://www.nvidia.com/object/nforce_udp_winxp_5.10.html
Posted on Dec 03, 2012
  • Christoher John
    Christoher John Feb 01, 2015
    Your awesome. I've been looking for these drivers for three days. E-Machine has no support for this machine anymore. Thank you soooo Much. God Bless You.
Thats because yr lan card os not on board, it requires a different driver. I can provide you with 2 solution 1. Buy a new LAN card or try getting the ethernet card driver from the internet(THIS IS NOT A VERY RELIABLE SOLUTION . )
SOURCE:
My hard drive got wiped and my video card vga compat and mutilmeiad audio and bel ethernet drivers are missing its a bell optpelx gx260 on windows xp pro
1. Reinstall OS ESPECIALLY XP service pack 3
2.Go Online to http://driverscollection.com, download an update your PC Bios and download other drivers.
3. Do not forget to install Antivirus(Avast).
Feb 27, 2011 | Packard Bell 1580509280 Network Adapter
I have a compaq presario 7478, when I got it, the cpu already had windows xp on it, so I recently reinstalled windows xp, and I can not connect to the internet because I am missing the ethernet controller...
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model computer/laptop and the XP Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 04, 2011 | Compaq Presario 7478 PC Desktop
I have an emachines t3256 desktop that i just reinstalled windows xp and now i cant get the network adapter to work its onboard and i cant find a driver on their website
Try installing a PCI ehternet card.Turn off the cpu then restart.The cpu will automatically (!?)detect the new hardware and even install the driver(generic).Then there you can get to the internet and get you E-machine drivers.It will also install the driver for your onboard ethernet(NIC) adapter and with that you are good to go.
Dec 04, 2010 | E-Machines eMachines Desktop PC
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
I'v put XP on my pc and now I can't get my wireless broadband to work
Hi, this is a common problem when one wipe there hard drive and reinstall an operating system, go to your common manufacture's website and download the driver for your wireless device and Ethernet controller. Recommendation: when ever you wiping your hard drive, also make a backup of your drivers by downloading them before you wipe. I recently wipe my computer, and i make sure i had all the device drivers before i wipe. Smile!
Sep 27, 2009 | Microsoft Windows XP Professional With...
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
No disk No Internet for drivers
http://www.soft32.com/s/Windows/Drivers/Digital_Camera_and_Webcam/3-375-13-0.htmlDownload drivers here richardm69
Dec 10, 2008 | Veo Connect Webcam
Wiped hard disk
Windows XP and Vista should have most of the drivers for the operating system to load. If any are missing after that and your internet connection is ethernet, then you should be able to get the rest of the drivers free from the samsung home site to make your laptop run properly.
Ivanotion.
Jan 06, 2008 | Computers & Internet
E-Machines T3256 PC Desktop Logo
8,680 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
