Palm Tungsten T3 Handheld Logo
Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change palm tungsten e2 from english to spanish!!!
How do I do this I've tried a hard reset and it doesn't prompt me for that switch!!!
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 448 Answers
  • Posted on Jan 09, 2009
Anonymous
Expert
Level 2:
Mentor:
Answers
448
Questions
Helped
149533
Points
868
System, languages. Email me
Palm tungsten E2
Does anything happen when you try to turn it on? Does anything respond or light up?
Frozen Blank Screen - soft reset doesn't work.... Do NOT want to do hard reset because all my data will be lost and it is my life line. I am panicking. Please help!
If you back up all your data on your desktop it will be restored with your next hotsync after the hard reset. I recommend the hard reset but if you really don't want to try that they I suggest you try using the free palm chat. Here is the link for that. Be sure to scroll to the bottom of the page and you will see palm Chat. Click on the link that says chat now and follow the prompts. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/supportservices/page_en.html
My palm e2 screen brings a frozen screen even after reset and no button whatsoever works, it can reset but freezes on the screen again,that is 0 alerts. even the power button does not work, only reset,...
You can try doing a hard reset. A hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is the link for directions for the Hard Reset:
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/solutions/article/42094_en.html#tx
HotSync problem:connection could not be
After you change the battery you need to do a hard reset. This will erase all the info in your pda so you want to make sure you have it all backed up on the palm desktop To do a hard reset follow these steps:
1. Hold down the power button.
2 While holding down the power button, use the tip of the stylus and inset it into the hole in the back of your pda and gently press and release the reset button in the back of your pda.
3. When you see the message that warns you about erasing all of the info on your hand held select continue.
4. When prompted follow the online directions to align the screen. After that you will want to do another hot sync. Best wishes.
2helpful
Hard Reset on Tungsten E2
for hard reset press reset hole and same time hold power button and release after 10 seconds choose yes when option given to erase all data. Please make sure you have backed up your data prior to hard reset as it will erase all personal information and set everything to factory default
1helpful
I have a Palm Tungsten\E2 that I want to remove all the
If you want to change the user (this will enable you to sync without old data) then yes, a hard reset. To do this hold down the power button and press the reset button. fter 2 seconds release the power button and delete all data when prompted. Now when you hotsync you will be prompted for a new user.
1helpful
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Damaged screen
Try a hard reset and if that doesn't work, drain your battery then recharge it. if that doesn't work than you'll just have to deal with it. I have a Palm Tungsten E2 and it has the same problem
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
