Hotpoint FFA90 Bottom Freezer Refrigerator Logo
Sean L Posted on Feb 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Should the fan in a Hotpoint FFA90 be running all the time on the cooling cycle as mine is not.
Have been having problems with the fridge not cooling, on dismantling the back there was quite a build up of ice. Have defrosted it and cleaned the drain hole plugged it back in and observed it go through a cool and a defrost cycle but the fan only came on for a second and has not run again.
keith jones
Level 3:
Master:
  • Hotpoint Master 747 Answers
  • Posted on Feb 10, 2018
keith jones
Hotpoint Master
Level 3:
Master:
Answers
747
Questions
Helped
314693
Points
1478
Most fan only go when the doors are closed ?
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 18, 2007
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
mgprice
Mike Price
  • 744 Answers
  • Posted on Jun 23, 2009
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Anonymous
  • Posted on Mar 01, 2010
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: [email protected]
MANY THANKS
Anonymous
  • 43501 Answers
  • Posted on Apr 21, 2010
SOURCE: my freezer side is not cooling properly
I would say that you have a small leak and are looking at major problems down the road...
Checkout this tip that I wrote about that...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Anonymous
  • 478 Answers
  • Posted on Jul 14, 2010
SOURCE: my freezer side in the hotpoint side by side
You have a defrost issue. You can check the defrost circuit by pulling the panal on back of fridg. Pull the back cover, look at bottom left for a three wire plug. Unplug refridgerator. Strip the ends of a jumperwire and jump the terminals l1 to defrost as lettered on the board. Plug in fridge and watch as defrost element thaws coils. If this is the case then you will need to replace the fridge's control board. Rock On!!
1helpful
My hotpoint freezer compartment is icing up.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Hotpoint ffa90 bottom freezer only cools down to minus 4
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
My fridge isn't getting cold
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Hotpoint FFA90 fridge freezer, fridge not cooling but freezer OK, was told vent proabaly blocked and to de-ice. Turned appliance off for two days, turned back on worked fine for 1 week but now fridge is...
i have the same problem. took apart the vent in the fridge at the top and thought maybe it needed replacing as that controls the amount of cold coming up from the freezer, but there doesn't seem to be any cold coming through. does anyone know if this is 'blown' through by a fan of some sort?
3helpful
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
3helpful
2answers
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
2helpful
3answers
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
