SanDisk Sansa Fuze MP3 Player Logo
Posted on Jun 16, 2017
SanDisk Sansa Fuze MP3 Player - FOLDER PROBLEMS
I purchased a Sansa Fuze MP3-player and loaded music files to the player, which took 1,87 Gb (of 2,0 Gb) of storage. The music files are present in the player, but I cannot find any music files when I open the music folder on the computer. I checked all the different folders to find out if I had saved the files to a wrong folder, but this is not the case. None of the folders shows any storage og music files.
How do I get around this problem?
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 27, 2008
SOURCE: Sandisk won't play or download any video
go under settings, and then click usb settings thier should be three types auto format, msc, and mtp. try one mode and see if your music or videos comes up, on the computer until you have tried all three, your data should be placed under 1 of these modes
Jean Sintulaire
  • 759 Answers
  • Posted on Mar 25, 2008
SOURCE: SanDisk Sansa m230
I would recommend that you update the firmware on your device..that usually solve the problem you are having..To update the firmware, follow the link below..
http://www.sandisk.com/DriverDownload/download.asp
I hope that helps
Please rate accordingly
Thank You
Computerrep
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Apr 08, 2008
SOURCE: wont open music folder
The folder option won't work particularly well - use Windows Media Player instead. If you continue to have problems:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
A
Anonymous
  • Posted on May 04, 2008
SOURCE: Missing MUSIC folder...
  1. hhuhihhygdydcxdsdfgyffxdfgtbgnhucdhyfgufrvcftygfcrvf
Anonymous
  • 144 Answers
  • Posted on May 08, 2008
SOURCE: sandisk sansa c250(2GB) MP3 player
Try this...
Step 1: open up your sansa folder
Step 2: In your player folder click tools --> folder options --> View.
Step 3: Under hidden files and folders click 'show hidden files and folders, click ok.
Step 4: The folder would now show up.
2helpful
2answers
Music folder is not detect
With a desktop computer and the USB cable you can transfer music to your SanDisk Sansa MP3 player. Simply hook the USB cable up to an available USB port and begin dragging music files to the folders of your SanDisk MP3 player1 Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
2 Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
3 Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player's memory are displayed.
4 Open a folder containing music files that is stored in your desktop computer's memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
5 Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
6 Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Can't load music onto my SanDisk Sanza Fuze Mp3 player
Itunes is what is known as proprietary software.
Which basically means that it only works with hardware of the same brand. (Apple- Ipod)
You will not be able Itunes to load mp3 files on a Sansa MP3 player.
Videos
Main page: all support for the Sansa Fuze is on this site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/session/L3NpZC94YzhjNkIqag%3D%3D/sno/0
Next page shows the files format for video (and music) to put onto the player:
http://kb.sandisk.com/app/answers/detail/a_id/29
Loading videos and photos from computer to the Fuze:
[How to obtain and use Sansa Media Converter]
http://kb.sandisk.com/app/answers/detail/a_id/101/related/1
Sansa Media Converter supported files on your computer:
http://kb.sandisk.com/app/answers/detail/a_id/32/related/1
Why is there no manual with my sansa fuze
For the Sansa Fuze there's a manual available in pdf format on the Sandisk support site:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Save this file to a location on your computer for later use.
When you explore "My Computer" the micro SD card with x GB memory, should be available as an extra external drive.
This drive will show up as an extra drive letter with a total capacity of x GB .
Sansa Fuze not Regestering Songs
The device only likes mp3's. Most other files don't show up.
How do you download music on your sandisk?
i know how to load music to sandisk sansa player.
NOTE: If you're using a MAC, see answer ID 1141
METHOD 1 - Load and sync music files using Windows Media Player
METHOD 2 - Copy & paste or drag & drop music files to the player through "My Computer".
1. Connect the Sansa player to the computer.
2. Double-click My Computer.
3. Locate and select the music file(s) to be copied to your Sansa player .
NOTE: You can select multiple files by holding the CTRL key down while clicking files. You can also select all the files on that particular folder by holding CTRL key then pressing A.
4. On your keyboard, hold the CTRL key then press C to copy.
5. Under My Computer, double-click the Sansa player.
NOTE: If the Sansa player is connected in MSC mode, you will see something similar to the image below:
If connected in MTP mode, you will see something similar to this:
6. Locate the Music folder and double-click to open.
NOTE: In MTP mode, you may need to double click on Internal Memory to get to the MUSIC folder.
7. Hold down the CTRL key on the keyboard then press V to paste the music files.
If you want to enjoy more music and video on Sansa Media Player, you can try this guide.
1helpful
Sansa Fuze MP3 Player - it is loading pictures to
Is it Loading Album Art? If this is the case, I don't think you'll be able to to stop it, Album art is typically very tiny in file size, and should have negligable impact on your available space. If it is syncing automatically to a folder, try moving any pictures in that folder somewhere else. This can probably be done with Album art as well, but you'll need to turn on the Setting "Show all Files (Including Hidden and System Files) in the Folder Options Dialogue box.
Sandisk sansa c250(2GB) MP3 player
Try this...
1helpful
3answers
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
