I have a Babylock EMP6. I can turn it on but can't hit the OK button to continue. I've tried doing the alignment that the manual says do but I get the double beep at the 2nd - 5th square. I can't seem to get aligned there. I was able to do an update of the software and noticed when I hit the USB button it gave me an error of no CF card inserted...so I pressed the CF button and it thought it was the USB.
This problem looks like it is the touchscreen problem, you can contact [email protected]
SOURCE: Babylock EMP6 problem with thread cutting
The thread cutting mechanism is dull and needs to be replaced or sharpened. I had the same problem on my machine. I found another post where another user said it has to be replaced every 150 hours of machine use, the cost was 62 dollars. My dealer would not sell me the parts he said I had to bring it in, so I decided to sharpen it myself. See picture for more details. To start take the two screws of the top of the chrome plate to reveal cutter that is above bobbin. The cutter is in two parts both chrome plated. The hook part is held in place by a copper plated screw, the blade (shown in picture hanging off to the side) is held in place by one small screw. I sharpened the blade on a fine grit Japanese water stone (brown block shown in picture) to a razor edge and about a 7 degree angle; the tip of the blade must ride on the hook. This still did not make the cutter work perfectly so I had to take the hook out and reform the small hole in the hook that the blade rides over with a the un-fluted end of a 5/64 high speed steel drill bit. Was not hard to do because the hook is not hardened steel, at least on mine. When putting the blade back on make sure it is resting against the rolled black pressed pin before tightening down.
SOURCE: How do I fix the error on a babylock emp6
I have found that this error most commonly is a result of a lot of thread caught in the cutting blades preventing the cutting blade from moving. See the "Cleaning around the Needle Plate" in the User Guide or "Cleaning of Knives and Rotary Hook" on page 316 (or 6-6) in the Service Manual located at http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf.
This is a translation of instruction from the Service Manual for the Brother PR600, the twin of the Babylock EMP6. I will testify this works because I just did it to stop the insanity of my EMP6 thinking everything was a 5x7 hoop. If you look on page 4-36 of the free PR620 manual http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf you will find the same exact set of instructions that are in the PR600 manual. So here are the exact steps to augment the manual's instructions.
1. Turn off the machine.
2. Press all three buttons (start, threader and cutter) and keep them pressed while turning the machine on.
3. Press MAIN BOARD TEST MODE.
4. Press A/D TEST.
5. Put the largest hoop on the machine (7 7/8 x 11 3/4).
6. Press LL.
7. Put the smallest hoop on the machine (1 1/2 x 2 3/8).
8. Press S.
9. Take the smallest hoop off the machine.
10 Slide the arm to where the knob on the arm is when the large hoop is on the machine.
11 The reading on the screen should be very close to the value that is in the LL setting.
12 If not, go through the large hoop steps (5-6) again.
13 Slide the arm to where the knob on the arm is when the smallest hoop is on the machine.
14 The reading on the screen should be very close to the value that is in the S setting.
15 If not, go through the smallest hoop steps (7-8) again.
16 Press close when you have both settings close. They need not be identical but they do need to be no further than 200 away from the screen value.
17 Turn the machine off.
18 Turn the machine back on, load a file, and see if you have the same results that I had; it will show the proper hoops when you press the hoop symbol and it will also center itself in the hoop properly.
You can buy the PR600 service manual online for about $12. However, you have the 620 manual for free and there is really very little difference. I have found the manual invaluable in saving me trips to the shop and doing my own repairs.
