Fan oven wont work
SOURCE: hi my leisure alta cookers
ceramic plates and the fan has to be replaced as you yourself know whats the problem.
you can get the required parts at this link
www.repairclinic.com
just enter the model number of your unit and the part you require.
and if u want to do it manually you can check out this following link
http://www.applianceaid.com/micro.html
feel free for further queries.
thanks.
SOURCE: having problems with fan assisted oven on leisure
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
SOURCE: TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
SOURCE: Have a Leisure roma 100 cooker model number
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
